Old 03-21-2004, 08:32 PM
michaelsd16c michaelsd16c is offline
Break Fluid Leaking?
I did a radmon check on my fuilds the other day, and to my suprise the brake fuild was just a little over minmum. The last time I check was about 6 months ago when I change the fluid and just got normal dot brake fuild. I don't know if this makes a diiferent's but I got AEM oversized rotors,brake pads and Goodridge briaded steels lines. I guess I use the brakes a little more then the average person. So is this noraml? should I just flush it out and get Honda dot 4 or 5 fuilds instead of crap one.
2000 Windstar transmission fluid leak olopezm Windstar 16 09-17-2010 08:51 PM
Brake fluid leak john3mo Lumina 3 11-16-2009 03:28 PM
'94 TS 3800: HUGE coolant leak - and other fluids jarl Trans Sport 23 10-31-2009 07:53 AM
2 problems in 1: Unresolved coolant leak/ power steering fluid leak NuBlackCavy Cavalier Problem Diagnosis 3 08-28-2005 04:00 PM
Leaking Break FLuid Aound the Front Passenger Tire jim43512 Cutlass Series 2 04-06-2005 07:18 PM
