Old 03-21-2004, 07:13 PM
Rooikat Rooikat is offline
Crankshaft out of time?
I just did the timing belt on my 96 turbo, and when all put back together, its showing the crankshaft being 5 degrees off according to the sprocket and the lower timing belt cover. The closest I can get it set is 5 degrees off according to the cover, but under the cover everything seems to be just fine, and looking down the plug holes, the number one piston seems to be at TDC, and the cams marks line up as well. My question is basically this, am I misreading the cover or am I missing something with the install? pics would help... thanks!
Old 03-21-2004, 07:49 PM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
Re: Crankshaft out of time?
Did you put the crank pulley on properly.
Ignition timing is totally different from valve timing
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
Old 03-21-2004, 08:12 PM
The crank pulley only goes on one way that I'm aware of, because its keyed. But the marks on the pulley don't line up with the marks on the plastic cover, so they show me as being 5 degrees off, which is making me worried.
Old 03-21-2004, 09:40 PM
kjewer1 kjewer1 is offline
AF - Advisor
The notch in the seperater plate is lined up to the mark cast in the front cover though?
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-21-2004, 10:08 PM
are you talking about the plate behind the timing belt? if so the marks on that plate and the marks on the crankshaft line up, just when the cover goes on and the sprocket goes on the notch on them don't line up
Old 03-22-2004, 03:07 AM
AF - Advisor
yes thats the seperator plate. IF thats on the mark, regardless of where the cams are, the timing notch on the crank pulley has to line up to the mark on the plastic tiing belt cover.... It is possible to put the plate on backwards, but that will through it off closer to ~60 degrees than 5... That is very odd. I'm ont sure what it can be.
Kevin Jewer
Old 03-22-2004, 03:42 PM
perhaps some pictures are in order?
Old 03-22-2004, 07:19 PM
Talon007's Avatar
Yes, that would be great. I am also very confused. I have done quite a few Tbelts and this is odd.
Chris Clark
www.Talon007.com
Turned crankshaft while timing belt was off HELP jack778 Probe 4 09-26-2010 06:04 AM
1996 Jimmy. How to remove crankshaft from tranny? bugyori Problem Diagnosis 8 04-05-2010 11:56 AM
96 geo metro crankshaft pulley bolt keeps snapping krayziemike4202 Metro 5 11-16-2009 05:38 PM
Stopped on Hwy and won't start kprellop Rodeo | Passport | MU 6 06-07-2009 01:35 AM
Chevy 350 cuts out! roknjock2 Chevrolet Classics 3 04-17-2009 07:13 AM
