Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-21-2004, 05:23 PM
elyingrid elyingrid is offline
Unhappy 92 Bad Idle Please Help.
I have a 92 camry with 164,000 that idles badly. It dies @ stop lighs, or whenever is in the drive position. However its fine when in parking and neutral. I been told that it cold be the Trotle Position Sensor (TSP). I just would like more info before buying parts in a guessing manner.
Please Advice....
ps. Have done tune up (wire, oil, spark plugs, ect... to no suscess)
Old 03-21-2004, 09:58 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 92 Bad Idle Please Help.
Check the vacuum hoses for bad connections or leaks, cracks, etc.
Get the ignition scoped to see if there is an ignition problem.
Check the fuel flow and pressure to see if there is a fuel problem. Clean the injectors.
Old 05-02-2004, 04:15 PM
Theophania Theophania is offline
I had that problem with my 92 Camry a few years ago. I had the fuel injectors cleaned and it idled correctly again.
95 tsi really low idle and stalls.. Please help please Brenthb25 Eclipse Problem Diagnosis 3 07-20-2010 10:41 PM
90 s10 blazer 4.3L stalling, erratic idle.. please help! gunner0352 Problem Diagnosis 6 09-18-2009 08:31 PM
89 Astro 4.3 Stalling and bad idle please help!!!! wingeier3 M Bodies 7 07-09-2007 02:17 PM
92 cavalier bad bad bad misfire.. please help jonny.chinn Cavalier 3 11-17-2006 08:20 PM
1994 5.7 - bad miss at idle please help silver100 C/K 13 05-25-2006 09:25 PM
