Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-21-2004, 02:46 PM
mustangiimadness mustangiimadness is offline
89 Ram 150 318 dies while driving!! Need help!
My truck quits while I am driving it. It will just cut out and then sometimes it comes right back. Sometimes I do need to pull over for a minute, but it always restarts. The problem is becoming more frequent. It seems like a fuel problem. Sometimes it won't start and I have to spray starting fluid in it to get it going, then it is fine. Could it be the fuel pump? They are expensive and I would hate to replace a good one. I am desperate. Please help me!!
Old 03-22-2004, 12:55 AM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: 89 Ram 150 318 dies while driving!! Need help!
Tune it up. Clean your injectors and stuff...
Old 05-20-2004, 07:36 PM
LTJGWorth's Avatar
LTJGWorth LTJGWorth is offline
You might want to try a new throttle positioning sensor. Kind of expensive, but you can get them at Auto Zone and install it yourself. It's located on the top, driver's side of the engine. Little peice of plastic with a plug and held onto the engine with 2 small bolts.
Old 05-20-2004, 08:32 PM
Actually, I got it fixed. The shop had a hard time, but they found it to be some switch in the distributor...
Old 05-21-2004, 08:20 PM
BleedDodge's Avatar
That would be it...
Old 05-28-2004, 11:59 PM
Ramit Ramit is offline
any time you have to toubleshoot an engine supported by a computer, you are better off to find someone that owns a scan tool such as a Snap-on, Pro Link. if you simply start replacing parts it won't be long before you have spent enough cash to have bought your own and find out that the problem was a bad wire in your harness.
Old 07-27-2004, 05:18 PM
MuleJohn MuleJohn is offline
do you know what they found in the distributor (switch) that was bad? I am having a problem with an 1988 318 PU and the shop it is at can't figure it out.
94-S10 - Dies while driving and other misc. wacky problems avlind S-10 4 09-30-2010 05:18 PM
'94 3800: dies while driving... jarl Trans Sport 5 11-29-2009 10:50 PM
'00 GP Sputtering while driving, need help lil_nages22 Grand Prix 21 12-11-2007 07:12 PM
car stalling while driving NEED HELP! francoisdm76 Regal 10 06-26-2006 08:09 AM
98 Ram 1500 4x4 dies while driving rockntn Ram Pickup | Ram SRT10 1 04-15-2004 11:18 AM
