Old 03-21-2004, 01:55 PM
SIKCRX SIKCRX is offline
can someone explain?
can someone tell me the difference b/t a fuel injected engine and a carbuerated engine, i know pretty much nothing about this kind of stuff. but i do know the basics. If i were to buy a crate engine would i have to have it carb'd or could it be made fuel injected? and what would be need to do this. Im deciding on what engine i want to get but i dont want to go carburated.
2.3L pumpin out 105 stock horses, WHAT NOW BISHES
Old 03-21-2004, 08:13 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Re: can someone explain?
The only major difference between a carbed longblock and a EFI is, 1.) the intake manfold(injector ports) and 2.) the timing cover on a carbed engine has a fuel pump on the driver side run off the timing chain. What are you thinking about ordering?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 03-21-2004, 09:42 PM
i really dont know. at first i was just going to rebuild a 302 out of a mustang and stroke it to a 331. but then i wanted to just buy a rotating assembly 331. i dont know which id rather want or which would preform better. any input as to what i should do for a daily driver. that will be n/a with a possiblity of nitrous. id hope to put out atleast 200-250rwhp.
Old 03-21-2004, 10:46 PM
i am also on a very limited budget being in highschool.
Old 03-22-2004, 06:22 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Re: Re: can someone explain?
Since you asked about carb F/I differences maybe you don't know this. A rotating assembly is just crank,rods,pistons,rings. It's not a short block. I'm worried that might be what you think it is.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 03-22-2004, 03:02 PM
Kirwan Kirwan is offline
There's very little difference in the engine itself. The long block is the same for injected vs carburated. Block, rotating assembly, heads, cam.
The intake manifold is different, but that just bolts on.
The big difference is that Fuel Injection involves a computer to run it; to turn a carb'd car into FI involves getting a number of expensive boxes.. or finding a junker to steal them from.
Carburators are much easier in comparison; bolt it on the intake, hook up the accelerator cable, fuel line and go. Course tuning a carb is much trickier.
Old 03-22-2004, 09:45 PM
Re: Re: Re: can someone explain?
oh yea i know that, i just used a poor choice of words, my bad.
Old 03-22-2004, 11:30 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
i like injected because you dont' have to mess around with complicated carb tuning. the most you really have to do with an injected vehicle is plug a laptop or small handheld tuner into it and change injector pulse width and stuff like that. or perhaps a fuel pressure regulator adjustment.
all my buddies are trying to get me to jump on the carb'd small block bandwagon, but i'm stickin with what i understand and like.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 03-22-2004, 11:44 PM
i would get a carb'd set up, but i simply dont know how to tune it. and i hear you get bad gas mileage from a carb.
Old 03-30-2004, 08:34 PM
price111 price111 is offline
Are you talking a swap from your 4-banger to the 5.0?? That is a very big job. There are wiring harnesses to match up, new exhaust, suspension is weaker, rear end is weaker, tranny is weaker.
I'm not trying to talk you out of it but this will not be a low buck switch. My suggestion, and many more experienced persons than I, is to buy an older 5.0 GT or LX and rebuild/replace that motor.
Another thing to consider is smog-legality. If you have emissions testing, they go by the VIN and that will tell them it's a 4 cylinder. You will flunk immediately.
Consider carefully before buying a crate engine and thinking it will "drop right in." If you go carbureted, which is a whole lot easier than EFI, you may still have a smog-legality problem.
The 4 cylinder brakes, tranny, suspension and rear are all designed for just that - a 4 cylinder engine.
When I was younger, cars were a lot simpler and these swaps were much easier. Now, it's a much different story. Do your research - there's a great forum for 5.0's at http://www.corral.net. Check it out and ask your questions from some folks over there who really know their stuff.
Good luck on your project - whatever way you decide to go. I'm just trying to give you some things to consider before you jump in.
Old 03-30-2004, 11:29 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 03-31-2004, 03:27 PM
people at corral.net dont know jack.
and i already know im going to have to upgrade brakes, suspension, and all that. i am saving up for a donor car.
Old 03-31-2004, 09:20 PM
Well, if you think the folks at the corral don't know
"crap," I've been around cars and hot rods for about 40 years and I learn things there all the time. Maybe it's just me... maybe you just had a bad experience.
Old 03-31-2004, 10:01 PM
na, they just dont have as many 2.3L people as stangnet does
