Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 03-21-2004, 01:47 PM
jeffharley jeffharley is offline
Send a message via AIM to jeffharley
cruise control quit working
On my 97 t-bird the cruise sontrol quit working.Recently I putin a new brake light switch.(a factory one) also put in a after market cd reciever with the wireing adapter kit.Would this have anything to do with the cruise control not working? everything else on the car works fine.Any help would be greatly appreciated.~Jeff~
Old 03-21-2004, 04:12 PM
michelq michelq is offline
Re: cruise control quit working
make sure spedometer is working,horn and brake light too check all fuses and let us know
Old 03-22-2004, 08:12 AM
I assume that the fuse for the brakes is ok because I have brake lights,speedo works fine,and so does the horn if this helps...~Jeff~
Old 03-22-2004, 09:51 AM
thunderbird muscle's Avatar
thunderbird muscle thunderbird muscle is offline
Probably the metal connector brushes that go between the steering wheel and column Happened to mine so my horn quit working had to replace them.
Old 03-24-2004, 06:28 AM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
The horn works, right? Probably not the brass contacts. And this happened right after you installed which? Did you replace the BO/O switch because the cruise didn't work or for some other reason? Do you have power to the cc switches?
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 03-24-2004, 12:47 PM
I replaced the brake light switch because it quit working,If I push on the cruise control on button and try to set it I get no light on the dash for the cruise and it does not engage..~Jeff~
Old 03-24-2004, 12:49 PM
how do I chech to see if I have power to c/c switches?~Jeff~
Old 03-24-2004, 01:51 PM
You'll have to pull the switches out. Don't know which wire is supposed to be hot and I don't have a manuel for a '97 so I can't say it is the same design as my '93.
Old 03-29-2004, 09:19 AM
thunderchicken2 thunderchicken2 is offline
I had the same problem and it was a bad fuse. My clock went out with it, so check the fuse with your clock and such.
Old 04-01-2004, 04:31 PM
I checked and the clock is working also checked all the fuses so I guess its time to look else where
Old 04-13-2004, 05:55 PM
does anyone know if there is a plug for the cruise control by the brake switch I might have knocked loose when I changed the brake light switch?I've tried to see up in there but can't really tell if something is'nt right
