Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 03-21-2004, 12:37 PM
PhiberOptik's Avatar
PhiberOptik PhiberOptik is offline
powerslot rotors
Does anyone ride these? I am looking into purchasing some, looking for a heads up of any pros/cons or suggestions on these. If anyone knows of some other slotted rotors that are good that would be helpfull as well. I am mainly getting them cause I like how they look. I have heard the cross drilled rotors can break easy but suposedly the slotted ones are better. Thanks
Old 03-21-2004, 10:07 PM
liquidflame8 liquidflame8 is offline
Re: powerslot rotors
i read a post on this forum with a big arguement about this subject and civicsiracer (who is a moderator here) said that a set of brembo blanks would be the best. because of the more mass they could absorb the most heat. if you are set on getting slotted you might want to look at the ebc rotors with the greenstuff pads.
Old 03-22-2004, 01:46 AM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
From what I understand, Power Slots are the best slotted around of one piece rotors out there. I have them on my Civic, and they wrok great! I even auto-X on them. Combined with a GOOD pad like Hawk HPS or HP+, they will give you BETTER than stock stoping power at a fraction of what a big brake kit will cost.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 03-22-2004, 07:53 AM
how long have you had them?
99 Civic EX
Si Spoiler
Type R mesh grill
Old 03-22-2004, 02:51 PM
Cali Guy
Re: Re: powerslot rotors
15k miles so far.
hessemer69 on AIM
Old 03-23-2004, 01:01 AM
Evil_MonkE Evil_MonkE is offline
Hey SilverY2KCivic, I was just wondering, for your break setup did you go with the packages that include the calipers and the rotors together? or did you just change the rotors and keep the stock calipers?
I'm asking cause I was looking into the AEM front break kit and the rear conversion kit. (i have a civic ex) (it's drum)
Old 03-23-2004, 01:06 AM
powerslot doesn't have a rotor/caliper combo
Old 03-23-2004, 07:32 AM
I found a group Buy on some Brembo drilled rotors, more then likely I won't jump on it but does anyone have these and really likes or hates them?
99 Civic EX
Si Spoiler
Type R mesh grill
Old 03-23-2004, 11:06 PM
Cali Guy
I can tell you one thing. ANY rotor that drilled out is bad right off the bat. Holes premote premature rotor failure such as warping and cracking. The holes are for NOTHING more than looks, and looks only. NASCAR stock cars use blank faced tuype rotors on them so that should tell you something right there. Basically put, the mosre of the brake surface you remove from the rotor, the worst it'll be at dissipating the heat that the pads generate against it. Don't get drilled rotors is the bottom line here.
hessemer69 on AIM
Old 03-23-2004, 11:08 PM
Cali Guy
hessemer69 on AIM
Old 03-28-2004, 01:43 AM
Re: Re: Re: powerslot rotors
...and i would have wasted my money on drilled rotors
Old 03-29-2004, 11:44 PM
do slotted rotors resist warpage better? cuz that seems to be the problem with mine. i always heat mine to hell
Old 03-30-2004, 01:37 AM
SenseiAccord SenseiAccord is offline
down shift to reduce warpage. nah j/j but i think cross drilled reduce warpage cuz its runs cooler. Slots are mostly designed to wipe the pad clean if im not mistaken.
Old 03-30-2004, 02:49 AM
Cali Guy
Incorrect.
X-drilled runs HOTTER than blank or slotted rotors. This is because heat dissipation is based off amount of surface area. The more the area, the better it can let off the heat. When you drill a rotor, you TAKE AWAY some of the surface area. Pretty simple concept here. Also when you drill into the rotor AFTER that fact of it being made (that's what Brembo rotors you see for $60 a piece are) that automatically WEAKENS the structural integrity of the rotor, which is the cause for premature failure and warpage of them. If X-drilled were SOO good, you'd see pro race teams (NASCAR, CART, IRL, etc...) using them. But they don't. I can tell you from personal experience having seen what they run, that almost all race teams use BLANK rotors, and ones that don't then use slotted. None use X-drilled though, they just cant take the high heat stress that a true 200mph+ car can endure.
I highly suggest reading through ALL 8 pages of this link to a very detailed discussion on the matter of X-drilled rotors.
hessemer69 on AIM
