Old 03-21-2004, 10:41 AM
Blk89CrxSi Blk89CrxSi is offline
Send a message via AIM to Blk89CrxSi
Unhappy D16a6 to D16z6 Swap... motor wont start
I did a d16z6 swap on my 89 Crx Si. I replace the 89 dizzy with the 92-95 dizzy. I dunno if I wired it correctly, but all of my spark plugs get spark. I also am getting fuel to my fuel rail. I have all the componets I need for the motor to start excepts for getting fuel through my injectors. How do I get the fuel into my motor? Did I wire something wrong? My harness is still the same and I plugged everything in right. Please help!!!!!!
Old 03-21-2004, 12:04 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: D16a6 to D16z6 Swap... motor wont start
well, are you running obd1 or obdo? if so, i don't think u can use the 92-95 dizzy 'less u convert to obd1. If you are still using ur si wiring harness, then you have to bolt up an 88-91 si dizzy.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 03-21-2004, 08:30 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
...from your description, it sounds like you're using OBD0 electronics..right? if so...throw the si dizzy back on... and if you didnt change any wiring, you should wire the injectors up the way they were....
SOLD!
Old 03-21-2004, 09:28 PM
TeamDraZtiK TeamDraZtiK is offline
Send a message via AIM to TeamDraZtiK
why couldn't he use the z6 dizzy?? they have the same amount of wires, same colors... just take your Si distributor clips and cut them off and cut off the z6 dizzy clips and re-wire, or is that what you did already? if so that shouldn't be problem.
does the 92-95 civic ex/si's have the injector resistor box???? find that out.. the 88-91 Si harness does but i dunno if the rest do..
Old 03-21-2004, 10:19 PM
Hammer Head Hammer Head is offline
wont work unless you go back to 88-91si dizzy ,and go back to peak and hold injectors with resister box
Old 03-21-2004, 10:35 PM
why wouldn't it work?
Old 03-21-2004, 10:55 PM
Re: Re: D16a6 to D16z6 Swap... motor wont start
obd1 uses saturated injectors thats why it wont work ,also you are better off using your 88-91 si intake manifold. just use the bare engine and bolt on your 88-91 dizzy and manifold with your injectors and ressister box and she will start up ,no prob.
Old 03-21-2004, 10:57 PM
you will have to modify your dizzy a bit
Old 03-22-2004, 12:00 AM
but what if you are using DSM 450cc injectors, will it work then?
Old 03-22-2004, 12:01 AM
91lxdreamer's Avatar
91lxdreamer 91lxdreamer is offline
Send a message via AIM to 91lxdreamer
Damn those are huge injectors
Official AF Primer Crew!
Updated 1-23-05
For sale: Stock 4-door corner lights. 13" stock wheels with 6 month old tires.
Old 03-22-2004, 12:02 AM
90civicracer's Avatar
90civicracer 90civicracer is offline
Send a message via AIM to 90civicracer
Yeah 450's are huge, espcially for our car. Is your car turbo'd right now or what?
***90 Civic EX 4 Door***
Ace$nyper: yea it did woo woo 4500 posts i should be ashamed *kills self*
90civicracer: haha you killed yourself you got
Ace$nyper: OMFG LOL that might be the funniest thing you EVER posted
bwhahahaha
boost baby!!! but will it work then or not?
Old 03-22-2004, 12:03 AM
I dont know man, were just here to whore it up baby, Ill check around and see what I can find
Updated 1-23-05
Old 03-22-2004, 12:05 AM
PSSHHHHHHHHHHHHT...What kind of turbo set-up are you going to get and about how much psi you going to run?
bwhahahaha
Old 03-22-2004, 12:06 AM
alright cool, it seems like it would work, if it gives spark out through the wires... whats the problem then??? i don't get it
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
