Old 03-21-2004, 09:08 AM
eswaroop eswaroop is offline
What to do? Valve adjustment-> Service messed up
Hi,
I gave in my 1999 honda accord 2.3 EX for valve adjustment hoping that after service, the slight tapping that was present would reduce and the mileage and power would go up , but Gosh, it has come down from 33mpg on highway to 27!! and the power is pathetic now. What to do? Did the service center mess up with the adjustment? (I took it to an acura dealer instead of a honda dealer)
Please reply!!
Thanks
eswaroop
Old 03-21-2004, 08:48 PM
rubix777's Avatar
rubix777 rubix777 is offline
Send a message via AIM to rubix777
if you still have the paper work, I think they're reputable enough to fix whatever they did wrong in the valve adjustment. but before you took the car home after the adjustment you should've test driven it with the mechanic in the car that way they can't say that you messed it up again yourself.
Old 03-24-2004, 12:15 AM
BullShifter's Avatar
Re: What to do? Valve adjustment-> Service messed up
It's pretty hard not to do a valve adjustment right if the tech knew what he was doing in the first place. Is is making more noise?
Take it back to dealer & politly bitch until they remove the valve cover & re-check the clearance. The car will need to cool down for a few hrs before the clearance can be properly checked.
In most areas Honda labor rates will be slightly cheaper than Acura Rates. Dealer group I worked for Honda - $92.00 per hr Acura - $98.00 Land Rover - $150.00 per hr
Old 03-24-2004, 01:02 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Do you have a 10mm ratchet and a feeler gauge? If not go buy them at the hardware store. Metric the intake should be around .15 and the exhaust should be around .17. If it isn't right take it back and bitch. But if the noise is gonw, then they probably did it right. And exactly how are you measuring fuell comsumption?
Old 03-24-2004, 10:14 AM
Re: Re: What to do? Valve adjustment-> Service messed up
I checked the clearances, they are off the mark. The mechanic does it by hearing some cams fall in place, basically a rule of thumb. I dont want to take it back there!!
Old 03-24-2004, 11:36 AM
Re: Re: Re: What to do? Valve adjustment-> Service messed up
Never let someone that checks clearances by ear work on you car. NEVER.
Old 03-24-2004, 10:23 PM
In order to check the valves & adjust properly each cylinder must be brought to TDC before adjusting each set a valves - 4 time the engine must turn.
Old 03-28-2004, 12:03 AM
Hi,
I did that, but I am still having problems. I posted it as a seperate thread,
http://www.automotiveforums.com/vbul...d.php?t=205916
Any help would be great..
Need help with 327 valve adjustment gr8hse67 Chevrolet Classics 6 04-04-2010 02:28 PM
How to adjust valves? lazerphreak Engineering/ Technical 1 05-08-2009 06:22 PM
Ok messed up valve adjustment NEED HELP CRXperiment '88 - '91 Civic | CRX | Wagon | Shuttlee 12 06-25-2006 12:46 AM
What do you do when people mess with your car? 99civic03 COMPLETELY off-topic 18 02-06-2004 12:06 AM
What Is Valve Adjustment For? DOHCGSR Integra 7 09-12-2001 01:11 AM
