Old 03-20-2004, 10:17 PM
Mistascott Mistascott is offline
distributor plug
My brother just got his 91 Lumina 3.1 repaired. It was leaking oil around the oil pan from what is called the "distributor plug." Where is this located and what is it for?
Old 03-21-2004, 12:57 PM
406Elcamino 406Elcamino is offline
Re: distributor plug
The distributor plug is located on top of the block below where the throttle body is on the intake. Can be hard to see. It is used for driving the oil pump.
Old 03-21-2004, 02:27 PM
Thanks. I was wondering if it was a hard to reach area because they charged us two hours worth of labor for it. I didn't think it would be a two hour job.
Old 03-21-2004, 10:00 PM
Depending on the intake setup you either have to remove the throttle body or the upper intake. I have done enough that I can't remember. If I remember right though in 91 you could remove the throttle body and do i that way.
Old 03-22-2004, 12:36 AM
Thanks for the clarification, I haven't dealt with the w bodies much before.
I heard that the reason there is a plug is because they used this block previously with a distributor but they took it out of the 91 block and just stuck a plug in where it would normally go. Is that true?
95 Caprice SW change distributor help (pulley removal) bigwar Caprice 11 02-26-2011 10:19 PM
2002 Distributor Install Procedure wmako M Bodies 2 02-02-2010 09:16 PM
distributor plug in pam3 S-10 0 06-12-2004 05:40 PM
