Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 03-20-2004, 09:37 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Misfiring ???
My friends mustang has been misfiring for the last two weeks or so.
We have replaced:
Spark plugs
Wires
Distributor cap
Rotor
Fuel filter
Air filter
It is a 1995 mustang GT
I seriously dont know what else could be causing it
For Sale 98 Eclipse GS, 5 spd
Old 03-20-2004, 10:35 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: Misfiring ???
Has the timing been adjusted recently? Try reseting the computer so it can re-learn the new degree if so. It could also be the ignition itself.
Old 03-20-2004, 10:40 PM
fordforlife's Avatar
fordforlife fordforlife is offline
Re: Misfiring ???
did u double check the firing order when u put the dist back on? ive done that before, and it'll run like crap.
Old 03-21-2004, 02:13 AM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Definitely check the timing before you go any further. Does the temperature outside or moisture(i.e. rain, fog, snow) play a role this at all?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 03-21-2004, 06:42 AM
ashah000's Avatar
Nope
The cap was checked. I think I am going to check the wires again just to make sure he didn't mix one of them up. Does any one know what order the wires go into each cylinder.
I'm not sure what you mean by the temp. Do you mean that, like only in the rain or snow it misfires. Then no. It does it in snow, rain, and a sunny day.
Old 03-21-2004, 10:10 AM
Re: Misfiring ???
Originally Posted by ashah000
Nope
if you have a haynes manual, it'll tell you the firing order, or autozone.com has it also. Then you can go from thier and figure out which wire goes where.
i believe he means that does it misfire only on say a day when its 50 degress outside, or when its 80 degress outsdie, or does that play a role.
Old 03-21-2004, 10:38 AM
ashah000's Avatar
The firing order is fine. The misfiring is orcurring whenever, the misfire does occurs in rain, sun, snow and everyday.
Old 03-21-2004, 10:53 AM
ashah000's Avatar
Re: Misfiring ???
He just told me that he does NOT have an CEL
Old 03-21-2004, 12:42 PM
ashah000's Avatar
Re: Misfiring ???
I rode in his car again, it is very bad. When he started his car it seemed fine, but then as it warmed up a little bit. It got terrible.
He also has a huge exhaust leak in his H-pipe, could that have anything to do with it?
Old 03-21-2004, 04:17 PM
Matts50's Avatar
Matts50 Matts50 is offline
Send a message via AIM to Matts50
Re: Misfiring ???
HAHAHAHA Don;t mean to laugh but I'm willing to bet money that I know what it is.
INSPECT ALL PLUG WIRES!
Is sounds like once the car heats up, a plus wire is touching/rubbing on a header and it ate away the rubber so now it is grounding out against the hot surface. This happened to me and a buddy of mine. It feels like it's running on 7 cylinders and it studders like a BEOTCH!
Good Luck!
Matt
Gears n Exhaust = Slow
Old 03-21-2004, 04:42 PM
ashah000's Avatar
Re: Misfiring ???
I will tell him to do that.
But I don't think that it is the problem. It was misfiring before and after we changed the wires, also we took all the wires out when we replaced the plugs yesterday, and it was doing it before all of that and it still is
Old 03-21-2004, 04:46 PM
Matts50's Avatar
Re: Re: Misfiring ???
Well it sounds like you guys have your bases covered! That's why I figure it must be something freak like that. Good Luck and keep us updated.
Matt
Old 03-21-2004, 05:22 PM
ashah000's Avatar
Re: Misfiring ???
Well I will tell him too check it.
I was just wondering what does the wire in the middle of the distributor run to. It is a box looking thing. What is it? Could that be causing it?
Old 03-21-2004, 05:25 PM
Matts50's Avatar
That would be the ignition coil. That can be tested at any Autozone or something like that.
Old 03-21-2004, 05:31 PM
ashah000's Avatar
Re: Misfiring ???
lol... O ok, I'm not familar with a distributor setup.
EDIT>>> BTW how hard are they to replace. I know on my car the coil is SUPER easy. But I don't remember exactly on his car if it looked hard or not. Hopefully it is easy
1998 Toyota 4Runner Possible Misfire bloomer510 4Runner/GX470 9 11-04-2015 05:18 PM
'99 Yukon misfires and won't start ZippyCT Yukon 10 05-29-2009 08:46 PM
02 Dakota Multiple/ Random Misfire, Cylinders 2,4,5,6 osuyaqui Dakota 3 04-09-2009 08:49 AM
Weird #3 cylinder misfire gesellman Trooper | SLX | Bighorn | Wizard 2 03-06-2009 11:31 PM
1996 Suburban Misfire when cold P0307 1993Suburban Suburban 5 02-23-2009 11:00 AM
Closed Thread
