Old 03-20-2004, 07:20 PM
drewh4386's Avatar
drewh4386 drewh4386 is offline
Send a message via AIM to drewh4386 Send a message via MSN to drewh4386 Send a message via Yahoo to drewh4386
Car Studdering
I am still waiting for my eclipse to be fixed before for I buy it. So I was wondering what an "ignition coil" is. It needs to be fixed. The mech said it makes the car studder when driving it. Is there anything else that could go wrong or need a good fixin? It is a 5-speed
Old 03-20-2004, 09:17 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: Car Studdering
In simple terms it is what the spark plugs wires run to. It looks like a box. You can just go out and but a new one and replace it. It wont take you more than 10 min.
For Sale 98 Eclipse GS, 5 spd
Old 03-20-2004, 11:06 PM
Import2nr99's Avatar
Import2nr99 Import2nr99 is offline
Re: Car Studdering
Go ahead and change out your plugs and wires too when he gets that taken care of. No reason not to make sure that everything is up to par. Also could be your injectors. but most likely the coil pack and plugs and wires will do it for you no problem.
V8's are like tampons, every pussy needs one!
Old 03-21-2004, 04:16 AM
drewh4386's Avatar
Re: Car Studdering
thanks
Old 03-21-2004, 09:11 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Car Studdering
I would say its hundreds of times more likely that the plugs and wires are the cause. Coil packs seem to fail very rarely on these cars. I'm still on my origianal with all my abuse after 175k miles. NGK stock type copper plugs gapped to .030, and stock or NGK wires.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-22-2004, 03:22 PM
1gEclipseTurbo 1gEclipseTurbo is offline
Send a message via AIM to 1gEclipseTurbo
Re: Car Studdering
i had the same studdering problems and i changed my wires and plugs and it took care of it
My Car Studders Talk2meYou Park Avenue 6 01-29-2012 03:28 PM
Would you drive a different car than your own? Lionkind Cars in General 0 04-01-2009 07:04 PM
Car studdering kreep Corrado 9 12-07-2004 08:30 PM
