Old 03-20-2004, 06:51 PM
sentosa sentosa is offline
Wink Honda Civic cold starting problem
Hi. Can someone help me . My honda Civic 1988 has twin CV carbs and when i start it from stone cold it runs vert ruff , but after 2 minutes it smooths out and runs on fast idle as it should. Card goes great and choke works ok. Problem only happens when car left overnight to get realy cold. If car left for 4 hours it runs great when started. Problem only happens when stone cold. Thanks
Old 03-22-2004, 09:53 AM
crxsirpr crxsirpr is offline
the ruf idle when the car is cold is alittle normal, try using carburetor cleaner on the carbs, check ur coolant temp. sensor. the car starts fine? or does it do blub blub blub vroom? or just cranks for a while then vroom? explain realy detailed and maybe i can help more.
97 S10 Blazer Hard Cold Start Problem Pilot423 Problem Diagnosis 1 10-14-2009 02:01 PM
1990 Honda Civic Intermittent Start Problem tuscamug '88 - '91 Civic | CRX | Wagon | Shuttlee 3 03-02-2004 07:22 PM
1990 Honda Civic Intermittent Start Problem tuscamug '88 - '91 Civic | CRX | Wagon | Shuttlee 0 03-01-2004 07:20 PM
