Old 03-20-2004, 06:47 PM
Someone500 Someone500 is offline
Question Engine problem
I just had to replace the head gasket on my 1991 5.7L Silverado.
That went without any problems, but when I went to start it, I there was a clicking coming from the distributer area.
Thought it was the oil pump, replaced it, but still have the problem, any ideas what it is?
(the was brass shavings in the oil pan too.)
Old 03-21-2004, 07:24 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: Engine problem
was the distributor shaft lined up with the oil pump drive?? does it run?? can you turn the oil pump shaft with a screwdriver through the distributor hole? does the cam gear look worn? sounds like the distributor might've popped up and striped the gear off.
Old 03-29-2004, 06:09 PM
Re: Engine problem
Yes, the shaft is lined up with the oil pump, it runs, the shaft turns, cam gear is fine, the distributer is not stripped.
The engine is still clicking, any ideas?
Old 06-17-2004, 07:23 PM
brokylm3 brokylm3 is offline
Smile
when you removed the fuel lines you probably just bent them up out of the way. when they were reinstalled back into place, they did not bend all the way to normal causing the lines to rub the firewall above the transmission. go under the vehicle and bend them down some more and the noise will go away.
Old 08-08-2004, 12:43 AM
stubbornmike stubbornmike is offline
Re: Engine problem
what was the brokym3 talking about? he had shavings in his oil pan after hearing a noise by his disrbutor... i would think with brass shavings u dropped the distrubor hold down down there or left a tool in there.
1998 Chevy Lumina Engine Problems? Engine Swap to 3.8 jonfit04 Lumina 12 11-10-2010 08:15 PM
02 Grand Am Hard Start when engine warm. ajbtrugreen Grand AM 3 08-01-2010 01:06 PM
1996 Olds Achieva Engine cuts out CivilWarJF Achieva 3 07-14-2009 11:26 PM
engine problems. always engine problems. alwaysproblems Fiero 2 04-09-2007 01:56 PM
b16a problem on crx, engine problem crxsirpr Let's get Technical! 0 03-02-2004 02:25 PM
