Old 03-20-2004, 12:31 PM
89stdzc 89stdzc is offline
Send a message via AIM to 89stdzc
ZC engine bogs out.. code 7/14
My engine was running well until yesterday. It has had code 14(EACV) and 7(TPS). Even with the codes it was running very well ( 9.7 in the 1/8th). After the car warms up it would bog when i went Wide-open-throttle. then it bogged from about 3000 rpm and up. i replaced the wires. I've check most everything except distributor. (about to do that)
I'm thinking i have a break in a wire and it's getting warm and seperating but don't know... ANY HELP??????????
Old 03-20-2004, 01:12 PM
Re: ZC engine bogs out.. code 7/14
i've now check Coil and distributor while hot nothing...... It only bogs when under load (while in gear) and i can "roll" the throttle and it will be ok but if i step on it fast it just bogs out.
Old 03-24-2004, 07:02 PM
transtec transtec is offline
did you get the codes from your ECU or from a diagnostic scanner
