Old 03-20-2004, 08:48 AM
Sonny01's Avatar
Sonny01 Sonny01 is offline
Clunk Sound From a Start and When Shifting
I have a 2000 Silverado K-1500 and it has developed a noise problem. When I start out from a stop and sometimes when shifting I get a metallic clunk from under the truck. Clunk is not the best word to discribe it, maybe a clink of a ching. It sounds like it's under the drivers seat but it could be anywhere. When I pull a trailer the noise stops. It happens while in 2WD. I have had the u joints looked at and they are tight. There is a little play when you turn the drive shaft at the differential, but it's not very much. Something is shifting back and forth and it's driving me nuts. When I come to a stop I am loading up something and when I move it unloads. Any help would would be appreciated.
Thanks,
Sonny
Old 03-21-2004, 01:12 PM
Miller52 Miller52 is offline
I knew a guy with a similiar problem but his happened alot more often but if remember right he said there is a heat gaurd for the exaust that was hitting his drive line. Might want to take a look and make sure nothing is swinging over and hitting it
Old 03-30-2004, 09:02 PM
mjgjr72 mjgjr72 is offline
Re: Clunk Sound From a Start and When Shifting
had same problem on same truck dealer changed output yoke on trans. after lift and tires also had similer problem installed torsion bars to eliminate rear spring twist causing drivesaft clunk at trans.
Old 06-09-2004, 11:29 PM
Sonny01's Avatar
Re: Re: Clunk Sound From a Start and When Shifting
I just re-read your reply for March and remember from a more recent post you bought your bars from RCD. I looked on the internet and found several and now I'm confused. I just want to stop the twist/clunk and maybe help with carrying a payload. The truck pulls and carrys great now...I just don't want to mess it up.
Sonny
Old 06-10-2004, 10:50 AM
macktoschool macktoschool is offline
Send a message via AIM to macktoschool
Re: Re: Re: Clunk Sound From a Start and When Shifting
Sonny
I have a 2000 Sierra with the same problem. I looked on Motoralldata, and there is a TSB on this. The "GM" answer is that due to the multiple tolerances in the drivetrain (Differential, Transfer Case, Transmission, Front Axle) that the clunking is just the resultant slop, or gear lash. I have 82,000 on mine, and it hasn't been an issue so far. I have replaced the U-Joints, using a severe duty type at the back, but like I said it hasn't seemed to cause any problems so far. Hope this helps.
Old 06-10-2004, 01:40 PM
Sonny
if you want to stop twist check jcwhitney for a set of traction springs, i used these first before i installed the bars.this took care of the clunk noise i had on take off and releaseing brake after hard stop, do not help with payload except to eliminate or reduce the amount the springs twist on take off or stop depending on how tight you set them. replaced with bars mostly for looks. hope this helps
[url]www.jcwhitney.com
Old 06-11-2004, 06:49 AM
Sonny01's Avatar
Re: Re: Re: Re: Clunk Sound From a Start and When Shifting
mjgjr72....is this the part that you put on your truck
http://www.jcwhitney.com/webapp/wcs/...&storeId=10101
PERFORMANCE TRACTION CONTROL SPRINGS
Fit pickups, SUVs and vans with 2"W or 2-1/2"W leaf springs and at least 20" between axle and front spring mount
Eliminate the spring "wrap" or twist during hard acceleration/deceleration that can cause power loss and lead to spring and U-joint damage or failure!
Prevent violent tire hopping and damaged drive-line components caused by rotation of axle housing and winding of leaf spring
A J.C. Whitney™ exclusive! Great on- or off-roading! Stop traction loss by ensuring tires transfer engine torque efficiently to the ground. Springs work on stock, lowered or lifted trucks. Precision alloy steel with great-looking, corrosion-resistant red powder-coat finish. Easy bolt-on installation. Effortless tuning. Complete with hardware and instructions. Sold in pairs.
They sell for 69.95. I just want to make sure I'm getting the right thing :-)
Sonny
Old 06-11-2004, 02:26 PM
Sonny01
yes, 2 1/2 measure across your sping to mage sure ,they are real easy to install and made a big differance when taking off and truck brakes slighty better.
Old 06-11-2004, 02:58 PM
Sonny01's Avatar
OK...I've ordered them and should receive them next week...I'll let you know how it turns out and thanks for all of your help.
Sonny
Old 06-17-2004, 11:35 AM
Sonny01's Avatar
Well...I installed the springs but it still clunks. Oh well...back to the drawing board :-)
Sonny
Old 06-17-2004, 11:51 AM
Thunderbolt Thunderbolt is offline
I had the exact same problem on my 98 C/K and after a month of searching I found it. The transfer case mount between the transfer case and the cross member was the cause. The mount was fine, But the bolts that hold the mount to the transfer case were loose. It was only a thread or two so I couldn't visually tell at first. I put a jack under the transfer case to check the mount and it clunked so I checked the bolts and low and behold they were not tight. After I tightened them the noise was gone.
Old 06-17-2004, 12:15 PM
Sonny
sorry it didn't help, but i hope they help in the long run, hate to have you waste hard earn money.
Click To See My Ride 2000 Chevy Silverado LT Z71 K1500 ecsb, 6" suspention lift, 4.56 gaers, 315/75r16 bfg mt, radix supercharger, gibson headers and cat back, trasgo shift kit, aluminum servos, nelson tune
Old 06-17-2004, 12:24 PM
Sonny01's Avatar
I tightened the u-bolts at the axle all the way like the instructions say. But how do I know how much to tighten the front bolts.
Old 06-17-2004, 12:42 PM
depends on how much give you want, they are mostly to keep the axle and springs from twisting to much. i'm a lead foot so i had mine almost against the spring, I left a little space to let the spring move over bumps. tighten them up a little at a time and see how it feels.
Old 06-18-2004, 08:29 PM
Sonny01's Avatar
I have about a half inch between the two springs. I have had them closer and farther apart but I can't seem to tell a differance. What should I be looking for?
Sonny
