Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 03-20-2004, 08:14 AM
jsh22 jsh22 is offline
Send a message via MSN to jsh22 Send a message via Yahoo to jsh22
Motor and Tranny Mounts
I had my '93 SC2 in earlier yesterday to do a fuel system cleaning and was told that I need to have the motor and transmission mounts checked. What is happening is when revving the engine in gear, the engine shakes. However when it's in neutral, it revs fine. I guess I'm looking to see how easy it is to check the mounts and about how much to replace them if necessary.
Josh
Old 03-21-2004, 03:41 AM
WildsideCreations WildsideCreations is offline
Re: Motor and Tranny Mounts
The monts are VERY easy to change. The top mount is 5 bolts total. cost about 40 bucks. the bottom mount is also 5 boltsbut you will need to remove the passenger sidewheel well first.cost also about 40 buckaroos.
It's not how fast you drive, It's how you drive fast.
Old 03-23-2004, 06:24 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
there is another mount identical to the one behind the wheel, it's under the battery and to get to it you have to remove the air intake.
http://www.saturnfans.com/forums/sho...threadid=25370
http://www.saturnfans.com/forums/sho...threadid=32086
here are two VERY bad mounts
Old 04-12-2004, 05:00 PM
SabreKhan's Avatar
SabreKhan SabreKhan is offline
The middle pedal is bad
Speaking of mounts... my Twistec aluminum/polyurethane mounts have been good for transferring torque to the road, but the other day I was driving around and one of the end-links broke. Not enough to drop the engine out the bottom (thank God), but enough to where I had to change it out right there on the side of the highway in Austin, TX. Luckily, I had my old mounts in the trunk. Has this ever happened to anybody else?
Look at the teeny picture of my car!
2004 Impreza WRX (SCCA DS 519)
2000 Saturn SL
Motor & Tranny Mount paulf717 Caravan | Voyager 0 02-13-2009 04:06 PM
96 Taurus How to swap engine and tranny mounts cyrusyn Taurus | Taurus Wagon 0 03-27-2007 09:58 PM
95 Chrysler Concorde, Motor and Transmission Mounts rmcnealsr Concorde 0 03-07-2007 05:42 PM
Motor swap, What year motor and tranny will fit? 96 blazer bjrjr16 Blazer 6 03-24-2006 05:47 PM
1966 chevy 2 nova big block motor and frame mounts ERTCCTY Nova 1 10-31-2005 11:57 PM
