Old 01-07-2002, 11:13 AM
e.cheng e.cheng is offline
creating, red/ clear tails. on a gen 5
is there any way of getting rid of the yellow plastic inside tail lights of the stock lights, i dont like the look of the red / clear. aftermarket, but if the stock wouldent have the yellow it would be great. . any links on how to pages. would help too. thanks .
Old 01-07-2002, 02:44 PM
EliteAccordPH's Avatar
EliteAccordPH EliteAccordPH is offline
There is a tool called the Dremel tool it basically is a small hand held cutter/chainsaw. Just take that and cut the amber piece inside into smaller pieces then remove the amber piece. Take your time as the chrome inside the tail light is easily scratched. Good luck
EliteAccord at Import Love
Old 01-07-2002, 07:20 PM
brads94accord brads94accord is offline
Send a message via ICQ to brads94accord Send a message via AIM to brads94accord
i tried cutting it into pieces and it got to be a pain, so i took my dremel and cut a hole in the side of the turn signal chamber then just pulled the plastice orange piece out, i have yet to reseal it back up. i only cut like three sides making a kind of door type thing. it hasn't had anycodensation problems or bulbs burnouts yet.
representin old school ph since april 2001, formerly UGAbrad94Accord
311 rules!
94 accord lx
16" konig reigns
3.25 inch drop on sprints and bec-techs.
clears all around, intake, custom rear section exhaust
farenheight plasma xenon headlights
click for my website
Old 01-07-2002, 07:44 PM
toilet_ninja toilet_ninja is offline
i used a soldering iron to get mines out. it took alot of time and patience, cause you have to be careful not to melt anything except the amber part. It does look really nice though, it's worth the effort.
Old 01-07-2002, 07:50 PM
there are some pics of mine cleared here http://www.automotiveforums.com/vbulletin/t19463.html
311 rules!
94 accord lx
16" konig reigns
Old 01-08-2002, 10:50 AM
brad: how easy was that to do, does the plastic slide out, from the side? thanks for the info guyz.
Old 01-08-2002, 03:30 PM
it pretty easy, heres a pic. you need to cut out a kinda door thing (blue highlighted), only three sides and the uncut side acts as a hinge. now look on the top and bottom of the blinker section on the back and you'll see orange tabs, break those off, then open up the hole you cut and use needle nose pliars to pull out the orange thing, it might take a little bending to get the thing out but you gotta do it. then close up the hole you cut out and seal it if you want. i didn't seal mine and i haven't had any problems. oh yeah, vacum out the plastic bits from cutting the hole
hope this helps.
311 rules!
94 accord lx
16" konig reigns
Old 01-09-2002, 12:20 PM
brad. thank you so much for the picture, i think i will try this, as soon as spring time comes along, im sitting in the middle of a canadian winter here. the picture helps alot as well , plan is to take those out and put some white blinkers in there. ^_^:flash:
Old 01-09-2002, 01:30 PM
5speedaccord 5speedaccord is offline
Send a message via AIM to 5speedaccord
gtig ri of ambers
Thanx guys. I was thinking about taking those out a few monthes ago but i wasnt so sure about how. i thought about breaking them but i wasnt sure how i would go about doing that. i forgot about the dremel. i just got done cutting them out and i love it. it looks pretty sweet I found that if you cut them horizantally (the long way so that it goes across the front and up the middle of the sides) that all you will really need to do is cut them in half and slide them right out. just make sure you stay as close to the middle as possible. Well i just thought i'd tell ya that. Thanx again. oh also be caurful o rubbing up against the part where the bulbs are screwed in. a little bit shouldnt hurt but be carful.
Old 01-09-2002, 09:52 PM
yeah, no problem man, i hope it works out well.
311 rules!
94 accord lx
16" konig reigns
Looking for 95 Maxima Red/Clear tail lights 95MaximaGXE Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 05-01-2002 12:21 AM
Where to buy red/ clear tail lights from 99-00 civic?... mauibound '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 13 03-08-2002 03:27 PM
Red/clear Tail Lights MRMAXIMA Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 03-02-2002 01:19 PM
Ci red/clear TAIL-LIGHT install..?? Stevo 3 Series 0 01-14-2002 05:50 PM
Maxima RED/CLEAR TAIL LIGHTS ???? MaxSpeedSE Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 01-04-2002 06:48 PM
