hi i have a 92 chevy scottsdale and it will not start it is getting gas just no spark from coil so replaced coil still no go it did the same thing a couple months ago and i went to tow it home started going down the road and tried it again and it fired up very weird but it seems if i run it everyday it runs fine but if i leave it sit for a couple day it won't start .
it just turns over but no spark. "squeak" |
That sounds alot like the distributer cap.
**1966 Chevy II** ![]() 355 SBC, Turbo 400, 5.13 gear, IHRA Certified to 8.50 in the 1/4 Last Race (10-6-07) So its been awhile... Dial: 6.77, RT: -.0001, 60': 1.4360, 1/8th: 6.7942 @ 100.65 mph Fastest Pass of '07 (10-6-07) 60': 1.4360, 330': 4.3453, 1/8th: 6.7942 @ 100.65 mph 25 and in BIG TIME Debt Crew member #2 Deuce's Wild Racing: Take a Ride on the WILD SIDE
Re: 92 chevy 1500 no start
did it die while u were driving or just wouldn't start one day cold?
You can turn the ignition to the "on" position and take a test light and check to see you have 12v at the hot wire connection for the coil. you should also have it when the key is turned to the "start" position. If you have it one or the other, but not both, then it is likely a wiring problem from the starter to your ignition switch or even the ignition switch itself. If you do have the 12v there during both positions, but no spark in any of the cylinders, the problem is either a defective coil, ignition module in the distributor, or rotor. If you get sparks in any of the cylinders, but not all, look for faulty plug wires, distributor cap, or fouled plugs GL! |
Well then, I have no idea!
it was warming up in the driveway and died i thought it was out of gas because i was running low . So i put gas in it but didn't run it for couple days and now no spark it did this once before when i put new starter in it but i was towing it home and just thought i would try it one last time and it fired up. i tested coil i am gtetting 12v in on and start position but no spark from coil this is a new coil too
and no spark from any wires either |
thank -you guys i got it it was the control mod in the distributer thanks again
