Go Back   Automotive Forums Car Chat > Cadillac > General Discussion
Old 03-19-2004, 05:49 PM
DRM DRM is offline
Unhappy 87 Brougham lack of power
I have an 87 Brougham 5 liter that has developed a lack of power. Timing is right, so is spark and fuel filter. Can anyone help.
Old 03-20-2004, 03:30 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: 87 Brougham lack of power
Old air filter, worn camshaft or a blocked catalytic converter come to mind
Old 03-24-2004, 05:24 PM
DRM DRM is offline
Changed catalytic converter, and recieved some power back. Still lacking, someone said to remove carb and clean EGR passages, any ideas?
Old 03-24-2004, 05:26 PM
DRM DRM is offline
One more question, I did a test for timing but am not sure if I removed and plugged the right vacuum hose, where exactly is it located?
Old 03-28-2004, 10:43 PM
kratefan kratefan is offline
Re: Re: 87 Brougham lack of power
It's rather severe, but have you tried GM's Top Engine Cleaner? The instructions are on the bottle. Basically you pour this stuff slowly down the carb while the engine is running until the bottle is half empty. Then you pour the rest of it down and let it kill the engine. After a time (20 minutes, I think) you restart the car. I'd remove the new cat first, though .
Jeff
Old 03-29-2004, 12:40 PM
DRM DRM is offline
No, I have not tried that but will give it a shot. Thanks
Old 05-18-2004, 01:32 AM
neon_boy82 neon_boy82 is offline
I'm assuming you have a 307 under the hood, so I just hope you realize that 140 hp isn't nearly enough to move a 4000 lb car around very quickly. I have the same exact car and I can't get nuthin' out of it. The first time I stepped on it at a red light I thought I was taking off in 3rd gear! Anyway, If you do get any big improvements let me know. Good Luck.
