Old 03-19-2004, 05:13 PM
lucidrain lucidrain is offline
Car shuts off while driving
I have a 95 Eagle talon esi that shuts off while i'm driving.Everything in the car is still on but have no response from the gas pedal. Rpm hit 0.
sometimes it starts right up or it takes about a day wait.
I've replaced the computer, fuel filter, crank position sensor,plugs and wires.
Any help would be appreciated
Old 03-19-2004, 05:30 PM
crazyford crazyford is offline
Re: Car shuts off while driving
I have a 96 aurora that did the same thing. At speeds up to 45mph. I replaced the feul pump and it stopped. 6 months later it started again. Again new feul pump. The second time I went with the best grade of fuel pump. I have not had the problem since (2 years now).
Old 03-19-2004, 11:28 PM
whyte Gsr b0i's Avatar
whyte Gsr b0i whyte Gsr b0i is offline
Send a message via AIM to whyte Gsr b0i
hahs.. mmk i wish you wouldnt had replaced some of those things.. . the ecu are very rare in causing such problems.. i'd try the Cam shaft postion sensor... but .. this in my experience is a sign of faulty crank shaft, rod, or balance shaft bearings..
97' talon Tsi fwd..
Rebuilding the engine.. should be running atleast 14.5 stock when i get that whip back together
'94 accord Lx coupe swaped ta Vtec...
1/4: 15.1
MODs: custom CAT.. VERY highflow.. Theres no Replacement for displacement.. and add me.. you can have times liek this too
90% driver 10% car
Nom'tawkin'bout
Old 03-22-2004, 07:37 AM
jp91tsi's Avatar
jp91tsi jp91tsi is offline
Send a message via AIM to jp91tsi
its the fuel pump, time for a 255lph
Old 03-24-2004, 09:56 AM
1 Fast TSI 1 Fast TSI is offline
Send a message via AIM to 1 Fast TSI
mine did the same thing
my 91 did the same thing and all i had to do was replace the fusible links and it was fixed havent had a problem since
[u][i][b]It Aint Braggin If You Can Back It Up
Old 03-27-2004, 03:59 PM
Talking
It was the poer tran module cost about $225. Runs like new now. Thanks
