Old 03-19-2004, 05:06 PM
Rossman2669 Rossman2669 is offline
Send a message via AIM to Rossman2669 Send a message via Yahoo to Rossman2669
Anyone Ever have this Problem???
I just bought a 1996 Mitsu 3000GT last fall. When I drove it today it was running fine and then all the sudden I lost all gears. This is an automatic car not standard.
You can put it in drive, reverse, neutral, but its as if it is not engaging. It feels like you are in nuetral and stepping on the gas.
I had no signs of transmission problems and it always shifted fine.
Any Ideas?????
Old 03-19-2004, 05:08 PM
One more thing. The car only has 54000 miles on it.
Old 03-20-2004, 07:29 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
Ouch. I only have manuals but when anything like that happens, it usually means rebuilding or replacing the tranny
I hope someone here might be able to offer a better prognosis, but something in the linkage has gone to hell.
Resistance Is Futile (If < 1ohm)
Old 03-20-2004, 07:48 PM
Hotshot8792 Hotshot8792 is offline
your shifter cable could have broke so while your shifting into reverse, drive, neutral or which ever gear, its not engaging it on the transmission. Just take a look, the cables are right underneath your intake pipe. Here's one way of checking it, take of your intake pipe, and get a buddy to stand right there and look to see if it moves while your changing the position from park to reverse to neutral etc
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 03-21-2004, 01:49 AM
Can the cable break while i was driving the car? If so wouldnt it of stayed in drive and not allowed me to put it into park. Or, when it breaks does the car go into neutral?
I was driving it and then i lost the gear and it felt like it was in neutral. Also, if I put it into park and then into Drive the doors lock. Would they lock if the cable was broke?
Any info helps
Old 03-21-2004, 11:21 AM
michelq michelq is offline
Re: Anyone Ever have this Problem???
sound like you lost oil pressure or out of fluid
check transmission fluid ,
Old 04-05-2004, 11:03 PM
Its fixed
Thanks for all suggestions. I had to have two things replaced.
Transmission pump
Transmission valves
end result....$1600
Never expected it.. all went at once..car was driving great.
Old 04-07-2004, 04:52 AM
thanks for posting the fix
