Old 03-19-2004, 04:33 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
95 GT Fuel Filter
Where is the fuel filter located on a 1995 mustang GT. I am going to help my friend replace it, and knowing the location would make it easier.
Also I was searching and I read that some mustangs need a special tool to replace it... does a 95 GT. Or can it just be done with a wrench.
Is there anything else that I may run into that is common with the fuel filters on these cars.
Thanks in advanced
For Sale 98 Eclipse GS, 5 spd
Old 03-19-2004, 07:49 PM
fordforlife's Avatar
fordforlife fordforlife is offline
Re: 95 GT Fuel Filter
Thanks in advanced
according to autozone, UNDER VEHICLE, PASSENGER SIDE, BELOW SEATING AREA, PASSENGER SIDE OF TRANSMISSION, MOUNTED ON FRAME IN FUEL LINE
Ive just replaced the one in my 93 t-bird a couple weeks ago, and it sound like they are in the same spot. Basically just look under your passenger seat(under the car) find the frame, find the fuel line (black hose) and in the line should be a cylinder shaped container a little bit larger than a coke can, with two connections on either end. I was told you needed a special tool also, but i was able to pop the connections things off with a reg screwdriver. I was careful and didnt damage them, but mine came with 1 connection, so just dont mess both of 'em up, and you'll be ok. any more questions let me know, i'll help if i can. Also when you pop 'em off, a little gas squirts out, nothing major, just have something to catch the excess in so your not working in gas. And dont smoke while working, lol
Old 03-19-2004, 08:19 PM
eillob's Avatar
eillob eillob is offline
My fuel filter was actually towards the back of the vehicle sort of under the rear seat under the car. It is right in front of the tank. Yes there is a special tool but I was able to remove this clip with needle nose pliers and a screwdriver.
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
Old 03-20-2004, 08:02 AM
ashah000's Avatar
Thank you both for your help.
I am going to go do this today so we'll see how it goes.
I did this on my eclipse a month or two ago, and it was very easy. Just a matter of removeing the fuel lines with a 19mm socket. It was very easy... but then I forgot which way it went back on. But i figured it out.
I just hope his mustang is this easy. I know the plugs we are replacing are a bi*** to get at.
Old 03-20-2004, 03:20 PM
g-luck dude! does it have stock headers on it?
Old 03-20-2004, 09:31 PM
ashah000's Avatar
We replaced the plugs-- it was fun belive me. (It had aftermarket headers)
And the fuel filter was easy. It came with two new tab things so we just broke the old ones off.
But his car is still misfiring, I am makeing a new post. Hopefully someone can help him.
