Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 03-19-2004, 12:55 PM
kvanderstel kvanderstel is offline
Frozen calipers
Okay, I just picked up an 85 Ranger for $500.00, that's good right? Anyway, I was driving it home and the front brakes have bound tight. It's like someone has their foot on the brake pedal permanent....
As far as I can tell it's only the front brakes, I never got the truck home. I'll get it towed soon. I released some fluid from the right front brake bleed nipple thinking maybe the mater cylinder was at fault, but it didn't seem to help, there was no visible extra pressure in the brake line.
The truck has been sitting and the weather has been wet, do you think the calipers could be stuck? And it's both sides!
Any suggestions would be helpful.......
Old 03-19-2004, 08:10 PM
2000mudder's Avatar
2000mudder 2000mudder is offline
it is possible the piston or slider bolts on the caliper are rusted. a large c-clamp will free them up temp untill u step on the peadle again. i suggest new calipers.
Old 03-22-2004, 01:12 AM
madmax40965 madmax40965 is offline
Re: Frozen calipers
You probably will have to replace the rubber brake lines in front. They are a cause of the symtoms you describe.
Old 05-05-2007, 12:46 AM
toddler62 toddler62 is offline
Re: Frozen calipers
if its been sitting Its probably the calipers. I'd replace them first But as Madmax said it can be the rubber brake lines also
Old 05-05-2007, 01:00 AM
e_powers e_powers is offline
Re: Frozen calipers
when it comes to brakes with frozen calipers and liability it is best just to replace it all around the wheel area and inspect the booster and a total flush of the fluid
starting to love my 93 ranger w/3.0 5 speed.
Old 05-20-2007, 10:23 AM
oshpunit987 oshpunit987 is offline
Re: Frozen calipers
It wouldn't be the rubber brake lines as he said he bleed the caliper at the bleeder and that didn't help. More than likely the calipers need replaced.
