Old 03-19-2004, 11:06 AM
angel_iz378 angel_iz378 is offline
Send a message via MSN to angel_iz378
Question cutting off
ok, i've put this question to several people i know and i get different answers, so here goes: i have a 94 cavy and for the last few weeks whenever i have to make a hard stop it acts like it wants to cut off, idle speed drops and comes this close to cutting off. well, yesterday, it finally cut off on me when i tried to stop too hard but it cranked right back up again just fine. please help. i've gotten that it may be the starter(which i believe as much as the sky is green) or maybe the fuel pump. also what would cause hesitation in the tranny shifting gears in an automatic?
I love humanity. It's people I can't stand.-Gil Grissom
Check out My NEW 2007 Cobalt LT "Pheonix" @ Car Domain
Old 03-19-2004, 09:21 PM
Joe W Joe W is offline
Re: cutting off
Doubt if it is either of these as the starter only comes into play when you start it,the first symptoms noticed with the fuel pump or filter is a hesitation at full throttle.
It seems to be a tune-up, sensor related or vacuum problem.
When was the last t/u?
Has the check engine light come on?
Check all of the vacuum lines to make sure there connected.
Let us know what happens.
Old 03-20-2004, 01:32 PM
cutting off
well, the check engine light comes on a lot off and on b/c i had the original engine replaced with one out of another model, so electrical codes tend to not match up alot. there's so much going on with it right now, i may just have to break down and take it to the mechanic
Old 03-21-2004, 11:45 AM
C_Sephiroth's Avatar
C_Sephiroth C_Sephiroth is offline
Send a message via AIM to C_Sephiroth
Re: cutting off
It almost sounds like the TCC isn't disengaging. if it doesn't it will cause a stalling when you stop. you might have sticking valves in the tranny
Homer: No T.V. No Beer makes Homer go... Something Something or another..............
Marge: Go Crazy......
Homer: Don't mind if I do.....muahahahahahbwauauauauauauau
Re: cutting off
