Old 03-19-2004, 11:01 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
question about TPS, and EACV
Hey guys....calling upon ur help again. I'm having a small problem with my car right now. It runs fine. The only problem is when my car is at WOT (wide open throttle, pedal all the way to the floor) it bogs. It doesn't do this unless the pedal is all the way to the floor. I checked my codes and i have a code 14 which is the EACV. I checked my wiring (since i did an si swap to a dx) and it was fine. So can a bad EACV cause this? Also, I bought an si throttle body online and it didn't have a TPS. so i pilfered one from a teg Throttle body. I never adjusted it. so i went to go adjust it and turning it in either direction doesn't affect the car at all. When i completely remove the TPS, nothing happens either! So could it be the TPS that's just making the car throw the EACV code since the TPS affects the EACV at all times. Let me know if u guys know anything.
It really doesn't matter to me that much. I got a b18 that im putting in and i just don't want this problem to follow me. If it's a problem with the intake manifold of my si then it won't follow me but if its in my wiring then my b18 will do the same thing.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 03-20-2004, 05:58 AM
Masta's Avatar
Masta Masta is offline
Send a message via ICQ to Masta Send a message via AIM to Masta
Re: question about TPS, and EACV
bump for a friend. No one knows?
1990 Honda CRX
Next Project: b16a
DREAMWORKS
Cardomain: http://www.cardomain.com/id/importscrx
Old 03-20-2004, 08:49 AM
89stdzc 89stdzc is offline
Send a message via AIM to 89stdzc
i currently have the same problem.....
i've checked tps wires/ <-ohms / timing belt/
it was running strong for 2 days and now when i hit the gas it just bogs out.
any help..........?
