Old 03-19-2004, 08:30 AM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Weird problem
For the last couple of days my car has been vibrating (at least I think, it could be a small misfire ) I can feel it the worst when I am going up hill in third between 2000-2500 rpm. It feels like it is vibrating but sometimes it feels like a misfire.
Could a misfire be small, last time I had a misfire problem, the car bogged like crazy, and the CEL blinked. Some times I feel it in other gears like 4th but mostly in 3rd.
I am confused if it is a misfire problem or something else
For Sale 98 Eclipse GS, 5 spd
Old 03-19-2004, 11:41 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Weird problem
what kind of car do you have? counld't be as easy as having to shift a higher rpm's going up a hill could it..
Old 03-19-2004, 11:49 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: Weird problem
Have you checked:
plugs
wires
PCV
fuel filter
air filter
Help us narrow it down.
Kris
2012 Genesis Coupe 2.0t
Old 03-19-2004, 01:57 PM
ashah000's Avatar
Re: Weird problem
98 eclipse gs
The fuel filter was replaced 1 month ago.
I will check the plugs and wires tonight. And the air filter is clean.
The only thing with the misfire is, could it be this small. Because sometimes it doesn't happen and sometimes it does. Sometimes it is smaller, sometimes bigger. Sometimes it feels like it is vibrating. And 98% of the time this happens in 3rd between 2-2.5k rpm.
Old 03-19-2004, 02:02 PM
ashah000's Avatar
Re: Re: Weird problem
It is the worst on a hill, it still happens on a normal road. But on the normal road it feels like it is less or sometimes I dont feel anything.
Old 03-19-2004, 03:37 PM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
Re: Weird problem
yeah,I would try the plugs and wires,im with lando
Old 03-19-2004, 04:27 PM
Actinide's Avatar
Actinide Actinide is offline
Send a message via AIM to Actinide Send a message via MSN to Actinide
Re: Weird problem
My did recently checked my uncle's 96 Mustang because it had the check engine light on. He connected his portable computer thing (i forgot what its called) and it reported a misfire. I was able to notice the vibration, but it was very minimal.
I guess your problem could be a misfire, even if it's small.
'97 Eclipse RS
- AEM Cold Air Intake
- MONZA Cat-Back exhaust
- 2.5 inch drop
Old 03-19-2004, 04:39 PM
ashah000's Avatar
Re: Weird problem
Can a misfire occur in only 3rd gear. I would think it would occur in others. Because whatever cylinder is misfiring, it has to misfire in other gears also.
Old 03-19-2004, 07:02 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
ur probably driving around at like 15mph in 3rd...
Old 03-19-2004, 07:04 PM
ashah000's Avatar
Re: Weird problem
OK I had that coming from last time. But no I am not.
Old 03-19-2004, 07:09 PM
Import2nr99's Avatar
Import2nr99 Import2nr99 is offline
Re: Weird problem
haha. I had the same problem wiehn accelerating hard or getting goin in the lower rpms. I changed my plugs and wires and it was all good from there. but as far as it being gear specific, I have no idea. Not too sure on the misfire either. I'm still tryin to get the hang of the whole engine side of things. good luck though
V8's are like tampons, every pussy needs one!
Old 03-19-2004, 08:04 PM
ashah000's Avatar
Re: Weird problem
I am going to change the plugs tomorrow. Lets hope that is the problem
Old 03-19-2004, 08:13 PM
anarchy1114's Avatar
anarchy1114 anarchy1114 is offline
Send a message via AIM to anarchy1114 Send a message via MSN to anarchy1114 Send a message via Yahoo to anarchy1114
i had the same problem but not gear specific. i changed the plugs and wires and it was all good for awhile. then it came back slightly and i put as grounding kit on the engine and it has totally solved my problem. who knos tho if it'll happen for u try it and see
If it has tits or tires it will give you problems, but atleast you can fix the problems with the tires
2007 Trailblazer - stock
97 GS-T -> lots of mods
98 GS ->total loss, now being parted out
Old 03-19-2004, 08:15 PM
EVOclipse EVOclipse is offline
Send a message via AIM to EVOclipse
Re: Weird problem
Would it be better or worse to add turbo sparkwires on a regular none turbo? to improve performance?
Old 03-19-2004, 08:19 PM
Re: Weird problem
you wouldn't really notice a difference. you're better off sticking with oem spec plugs, or ngk's. 95gskracer recommends stock wires or maybe magnecore. I'll take his word for it. I wouldn't bother with them. I'd stick with things that are made for your car to be safe
