Old 03-19-2004, 08:16 AM
Neronian Neronian is offline
Newbie...H22 swap help.
have a accord 97' and the engine just gave out on me.
Now I am thinking about getting H22. I have a friend who can get
a 97' H22A USDM and install for $3,600. I think it is a good deal.
I have been doing some research on the H22A engine. My friend told me that
the engine came from "97 Prelude SH." Now, I am confused.
What is so special about Prelude SH? How can I tell that the engine really come from "Prelude SH." I do not want to get ripped off.
Another question is, I already have a turbo kit but it's for accord engine. I am thinking about turbo the H22. I can have it custom fit H22 for $500 but my friend does not recomend turbo H22.
What do I have to do to get 250Hp with out heavy mod or spent too much money?
Please be kind.......
Old 03-19-2004, 03:33 PM
Drfthis's Avatar
Drfthis Drfthis is offline
Send a message via AIM to Drfthis
Re: Newbie...H22 swap help.
the H22 puts ot 200 stock
Any fool can take a fast car and beat a slow car, but a real driver can take that slow car and beat that fast car.
what it takes, 10% car 100% driver
Old 03-19-2004, 07:39 PM
92lx 92lx is offline
The H22 came from Prelude VTEC trim. There is an "upgraded" h22a in the type-sh prelude. The only trouble with the turbo kit for the accord, on the prelude, is that the turbo exhaust manifold won't fit due to the h22 having a different manifold - but no problem, as the exhaust manifolds for a turbo h22 are readily available. And selling the Accord one could make you some money for sure.
Anyhow, as for getting it up over 250hp, the H22 can be pushed over 250hp with a small shot of nitrous (50 shot even, and would be rather safe mind you). Umm, otherwise, it'd be easily obtained with bolt-ons, some minor head work, and a set of new camshafts.
The H22, btw, only put out 200hp in the JDM version (the version easily purchasable from engine importers)....the state-side version was only 190hp. There is some debate over that, but for the most part everyone agrees, 190 for the USDM version, and 200hp for the JDM version.
Might want to check out my signature as well
Hope this helps!
- Nathan
Old 03-20-2004, 01:25 AM
whyte Gsr b0i's Avatar
whyte Gsr b0i whyte Gsr b0i is offline
Send a message via AIM to whyte Gsr b0i
dont get the SH !!! honda meant to put sh*t.... but yeahs dont get it.. you want a 95 Vtec h22... models 96 and up have mor eand more restrictions the new they get... plus 95 models are the stroongest motors.. trust me.. get JDM..
97' talon Tsi fwd..
Rebuilding the engine.. should be running atleast 14.5 stock when i get that whip back together
'94 accord Lx coupe swaped ta Vtec...
1/4: 15.1
MODs: custom CAT.. VERY highflow.. Theres no Replacement for displacement.. and add me.. you can have times liek this too
90% driver 10% car
Nom'tawkin'bout
Old 03-20-2004, 07:27 AM
Re: Re: Newbie...H22 swap help.
I think H22 usdm is good for turbo be cause it has lower compresion.
Am I right?
Old 03-20-2004, 10:15 AM
I have another questions.
I have AEM fuelrail and AEM underdrive pulley form my accord 97. I was wondering if I can use them with H22?
Old 03-20-2004, 11:50 AM
fuel rail....yes
underdrive ...no, different type of belts used on the prelude.
For turbo, no matter which h22 you use, you'd want to lower the compression back a bit. However, you want one of the closed deck h22's, which are those made from 93-97 if my memory serves me right (I just woke up, so I could be wrong). After that, they switched to open deck, which is a weaker block.
- Nathan
Old 03-20-2004, 01:54 PM
Originally Posted by 92lx
fuel rail....yes
- Nathan
Thank for the quick reply.
I am going to take a look at the engines in 2 days.Right now I have to choices
97' and 98' h22. How can I find the information about open and close deck engine? I was looking at 98' because it was newer. Since you told me 98 or later engine had aweaker block. I probable go with the 97' but I want to make sure if the 98' is opened block.
Nat
Old 03-21-2004, 07:38 PM
In the future, I plan to get Hondata ECU or AEM EMS. Which one is better?
Old 03-23-2004, 06:51 PM
Can I also use spark plug wires from Accord 97 V-tech with 98' usdm H22?
Old 03-24-2004, 11:46 AM
dutchaccord dutchaccord is offline
No, they wont fit
Check
www.h22a.org
board.hondasociety.com
board.accordtuner.com
www.accordinglydone.com
Stefan
1 st........2nd........3rd
====== ==== == [[ ] ] H22A
Upcomming: Porche 964 brake swap
In progres: Boostin the H22
Old 04-03-2004, 10:25 PM
What kind of hondata ecu should I use? Is hondata S200 be good enough for turbo set up? What is Hondata k series?
Old 04-04-2004, 12:40 PM
Ask Bustedlx on board.hondasociety.com... he knows all about Hondata
Old 04-11-2004, 12:01 PM
What is stage 3 ACT? Is it a factory oem HD clutch pressure plate, throw-out bearing, pilot bearing (optional on some cars)and an ACT 6 puk solid high performance ceramic/copper disc combo?
What is diffe between factory oem HD clutch pressure plate, throw-out bearing, pilot bearing (optional on some cars), a ACT 6 puk solid high performance ceramic/copper disc combo and Exedy Racing Pressure Plate, Exedy Organic Full-face Racing Disc, Throwout Bearing, Pilot Bearing (not required), Alignment Tool, XACT StreetLite Racing Flywheel (11.9lbs)?
Which one is better the OEM HD clutch pressure plate with ACT 6 puk solid high performance ceramic/copper disc combo or Exedy Racing Pressure Plate, Exedy Organic Full-face Racing Disc, Throwout Bearing, Pilot Bearing (not required), Alignment Tool?
i forgot the factory oem HD clutch pressure plate with an ACT 6 puk solid high performance ceramic/copper disc combo + FIDANZA FLYWHEEL. is just $361.95
Exedy Organic Racing Clutch Kit & XACT StreetLite Flywheel is $490.
Which one should I get?
