Go Back   Automotive Forums .com Car Chat > Chevrolet > Camaro | Firebird > Camaro Discussions
Old 03-19-2004, 09:12 AM   #1
sipote
Unhappy Has anyone ever had this problem?
I have a 97 chevy camaro V6 3.8 and i just bought it like 2 months ago, i replaced the power steering pump and after that the engine light came on a few days later the car just would not start, would crank but not start. the problem is that it keeps blowing up the PCM fues, any clue what could be causing my car to do this?
thank you
sipote is offline   Reply With Quote
Old 03-19-2004, 11:52 AM   #2
sipote
Re: Has anyone ever had this problem?
any ideas why my fuse may be getting blown on my PCM? when car moves?
thanks
Old 03-19-2004, 01:37 PM   #3
Chevyracincamaro
Chevyracincamaro's Avatar
sounds like when you replaced the pump you might have done something to the harness that caused a short somewhere, maybe you accidentally stripped a wire somewhere thats grounding to the body...
Chevyracincamaro is offline   Reply With Quote
Old 03-19-2004, 01:53 PM   #4
sipote
maybe that is possible and we replaced the the seals on the valve covers and that took him at least a whole day to take it off and put it back the one on the passenger side where the dip stick for the transmission is..and blows when the car is moving..
thanks
Old 03-19-2004, 08:33 PM   #5
4onFloor
4onFloor's Avatar
get a volt meter or ohm meter, pull the pcm fuse. i think there should be 12 volts to one side of the fuse even with the ignition off, but try it both ways. find which side is hot, then check continuity to ground on the other side, or check resistance to ground.
4onFloor is offline   Reply With Quote
Old 03-20-2004, 08:25 PM   #6
sipote
now the car blows the fuse right away as soon as we put the fuse in the car the fuse blows it is fuse 13 initial PCM any ideas on what wires go to fuse 13?
thanks
Old 03-20-2004, 08:49 PM   #7
89IROC&RS
89IROC&RS's Avatar
definately sounds like a short, looks like you pinched a wire somewhere, and it is grounding to the chassis, so as soon as you put the wire in, ill look into what color wires are the power feed for the PCM, i would assume it is a large guage orange wire. i would just inspect all the harnesses around the areas that work was performed, and see if you can eyeball a damaged section.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
89IROC&RS is offline   Reply With Quote
Old 03-21-2004, 12:05 AM   #8
Jm93
Jm93's Avatar
Send a message via ICQ to Jm93 Send a message via AIM to Jm93 Send a message via MSN to Jm93 Send a message via Yahoo to Jm93
definetley sounds like a short. do like the above fellow said, and check all harnesses and whatnot around the area you worked.
http://members.cardomain.com/jm9301
It runs once more. Parked for winter.
Jm93 is offline   Reply With Quote
Old 03-21-2004, 12:58 AM   #9
4onFloor
4onFloor's Avatar
i think on a 3rd gen, the fused power to the "ecm" is a pink wire with a black stripe. but i dont know if it's the same for the 4th gen pcm.
