Go Back   Automotive Forums Car Chat > Toyota > MR2/MR-S
Old 03-19-2004, 01:09 AM
cuongnguyen1 cuongnguyen1 is offline
apexi super intake help
HI GUYS I got an apexi super intake but the airflow meter or whatever on the pipe is diferent and the wire connetor is diferent. the sensor on the apexi is a denso and my 93 turbo stock sensor is also denso. but the stock one has four male while the apexi has two. i need help please.
Old 03-19-2004, 02:43 PM
JekylandHyde's Avatar
JekylandHyde JekylandHyde is offline
AF - Advisor
Re: apexi super intake help
Where did you buy this?
The Apexi filter kit does not come with a AFM.
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment
Old 03-19-2004, 11:27 PM
thanks for replying, I bought it on ebay. and it says apexi super intake. but it has thumb size hole on the pipe with a denso sensor or something of that sort. if i unplug the wire from the stock intake the engine will run a little rough and sometime it will stop.
Old 03-20-2004, 06:34 AM
AF - Advisor
Was this filter "advertised" specifically for a turbo MR2?
How are you unplugging the wire to the OEM AFM?
The correct way is to use the very thin C-clip that goes around the wire.
If you used the screw on either side of the wire, I am sorry to inform you that you destroyed the AFM.
Old 03-20-2004, 08:32 AM
I pull the clip out first then unplug the wire, after i unplug the wire my check engine light also came on.
Old 03-20-2004, 11:28 AM
AF - Advisor
Well the check engine should come on, it has to have that signal from the AFM.
It doesn't sound like you bought a filter made for the MR2. Filters that are made for the MR2 should only include the cone-style filter, and adapter plate to mount it onto the AFM and maybe a bracket ... nothing else.
Old 03-21-2004, 01:57 AM
thanks for your help my friend. By the way what kind of intake should get for my car to increase horses?
Old 03-21-2004, 05:59 AM
AF - Advisor
The actual K&N FIPK for the MR2 and the actual Apexi kit made for the MR2 are the best choices out there. I have always used K&N.
Just make sure you but the FIPK (it is the whole cone filter kit) and not just a K&N drop-in filter. K&N makes stock replacement filters that flow better than the OEM paper ones, but they are not nearly as good as the K&N cones sets.
Good luck.
Old 04-01-2004, 11:21 AM
TBeck2000 TBeck2000 is offline
Send a message via ICQ to TBeck2000 Send a message via AIM to TBeck2000 Send a message via Yahoo to TBeck2000
I'm not sure if the name means too much, but I have always seen the Apexi intake for the MR2 turbo referred to as a "Power Intake". The "Super Intake" reference can be found associated with MK3 Supras, Skylines, DSMs, etc.
I believe that the Power Intake is a newer design than the Super Intake because of this wording on several vendors' sites: http://www.pagparts.com/air_intake/p...ipwi/cat_splsh, "The Apexi Power Intake evolved from the highly successful Apexi Super Intake."
Tim Beck
'91 TD-06 Superwhite
Apexi Super VTEC AFC-2 Settings? jjonathanj1 Integra 2 02-05-2004 04:21 PM
Apexi super AFC( for sale) Turbogrunt Forced Induction 0 10-08-2003 07:35 PM
Apexi Super Suction kit to suit 33/34GTR 96GTR33 Classifieds 0 03-29-2002 07:15 AM
Apexi Super AFC on 5th Gen Max? jhans114 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 11-13-2001 09:20 AM
Apexi super AFC dhamo69 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 06-28-2001 02:11 PM
