Old 03-19-2004, 12:16 AM
NWChevyGuy's Avatar
NWChevyGuy NWChevyGuy is offline
Pinging After Hypertech Install
I programed my computer with a Hypertech Programmer this week. I run Chevron Super for gas, but the motor (8.1) still pings. It pings in both the low octane and high octane setting in the hypertech.
Any Ideas of what I can do to the motor (tune-upwise maybe) to stop the pinging?
Thanks!
Old 03-19-2004, 07:14 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: Pinging After Hypertech Install
Mine did this after I first installed it, but then I switched to Supereme (93 octane) and haven't reually had anymore problems. It will slightly ping under a load while in overdirve.(climbing a slight grade..etc.)
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 03-19-2004, 04:12 PM
NWChevyGuy's Avatar
I was thinking mine would stop pinging too after I put Supreme gas in it, but it still pings with Supreme. Anyone else have any ideas of how to stop the pinging? It does it with a cold engine too.
Thanks
Old 05-01-2004, 10:51 AM
NWChevyGuy's Avatar
Well the pinging never stopped. Even with 3 cans of Octane Boost in my tank of Super, and I even ran the lower octane setting in the programmer. I just switched back to Factory settings and the truck is much faster, because everytime it pinged before, it hesitated.
Any ideas why it would ping that much? Hypertech swears its my truck's problem.
Old 05-01-2004, 02:50 PM
jeverett's Avatar
I'm still not sure. I'm selling my Hypertech as soon as I can and getting a Nelson tune.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 05-01-2004, 03:28 PM
NWChevyGuy's Avatar
Probably a good idea... for now... im just using my hypertech to adjust my rev limiter and tire height... its doing no engine programming though... oh well... it would have been 300 to get the tire height fixed at a speedo shop so not a HUGE deal i guess... any other ideas on how to stop the pinging would be cool... thanks!
Old 05-01-2004, 06:36 PM
chuckwi11 chuckwi11 is offline
Chevron Techron
I ahve had a lot of success clearing poor performance due to clogged or dirty injectors using this product. You may want to igve it a shot and see if it helps. It's not an octane booster but a fuel system cleaner... I'm not running a hypertech right now but have in the past...
Old 05-01-2004, 08:11 PM
jeverett's Avatar
I have also heard that a lean fuel condition could cause pinging, so at the next oil change, I'm also changing my fuel filter again. Maybe that'll fix it until I can sell it. If you know anyone that has a 99 that needs a hypertech, let me know.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 05-02-2004, 02:12 AM
NWChevyGuy's Avatar
I'll let you know. I have changed my fuel filter recently, but I'll do it again.. along with a strong fuel injecter cleaner. I dont think the plugs would cause the pinging... its mostly a lean thing I think. Hypertech thinks its because of my Airaid air intake giving the motor more air and causeing it to lean out. I think thats BS because just an air intake wont cause it to go THAT lean will it?
Old 05-02-2004, 08:01 PM
jeverett's Avatar
I don't think so, I have an FIPK and before my head gakets blew, it didn't ping hardley at all.... I'm changing my filter 2morrow and I'll let you know how it worked.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 05-03-2004, 10:48 PM
jeverett's Avatar
I just changed my oil and while I was under the truck, changed my fuel filter. It really did make a difference in the pinging..I never knew gas was so dirty, I had just changed the filter not long ago. Anyhow, I guess mine was just a lean condition b/c I still have my Hypertech installed, but it barely pings at all...just barely under a slight load.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 08-08-2004, 01:29 AM
stubbornmike stubbornmike is offline
hypertech will do that that how it increases your horse power by advancing your timing!
Old 08-08-2004, 02:42 PM
red00lght's Avatar
red00lght red00lght is offline
You know what's weird? I bought Jayson's hypertech for my 4.8....and with the higher octane setting, I get no pinging...even running on regular unleaded! I did get a performance increase so I know it is programmed properly.
Sounds like this pinging thing can vary from vehicle to vehicle. My truck has over 50k miles and is a 99....so it isn't brand new either. Maybe the different engines are more susceptible to too much timing?
Old 08-09-2004, 06:57 AM
jeverett's Avatar
I think my ping problem was my engine...my new one runs SOOOO much better!
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
engine loud and knocks/pings after car wash dadockter Dakota 2 01-17-2010 09:04 AM
Engine pinging after water pump installation tmtroyer Engineering/ Technical 1 04-09-2005 10:11 PM
Engine Pinging after backfire Dutch Dakota 98 Dakota 6 08-23-2004 06:33 PM
shudder after axle install born2speed Integra 1 08-11-2002 06:31 PM
Lost Boost After Head Install turbocivic4 Forced Induction 6 01-17-2002 10:33 PM
