| Off-Topic Talk about anything other than cars. |
Intresting idea..
i'll admit im a newbee. I just bought my gsx last month. But ive always wonderd and a bit currious what would happen if you rerouted your air conditioning system into your intake pipe or even ypi uip to cool off the return air. has anyone heard of this? is it possable? would this affect the your psi level? Scott
Re: Intresting idea..
a good thought but your air conditioning would take up more power to turn on than you would gain.
summer time 105 degress?
That's just like using a battery to power your battery charger... to charge your battery.
A/C steals power from the motor, and there is an efficiency below 100%, so you will never regain all of the power in any scenario like this. |
Its the same scenario as a supercharger. Draws power from the motor to run, but if implemented properly, will result in a net gain in power
When you consider what efficient intercooling is worth, losing 20 hp to the AC compressor seems a small price to pay. No matter how much power you make, the AC compressor doesnt draw any more than it does stock. Its not as simple as just blowing cold air into the intake of course. You have to put the AC condenser in your intake path. Not terribly complicated, but takes some fabrication.This has been done. Flaco Racing did this on a 3rd gen rx7, 2 rotor, and put down 800 to the wheels. Seems to work for them. You might be able to find some info in a search, or if they have a site.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
I never thought of that hmmmm.like joewagon said,with the power you give up running ac,i don't know if it would be worth it, but if your good ,i guess anything can work
Re: Re: Intresting idea..
you could also get one of those electric blowers on ebay too, oh and one of those resistor mod's....
![]() j/k i think for the $$ it would take to correctly implement the system you could probably find a much more cost effective mod... |
how bout a custom fmic with a space in it for the relocated ac condenser i dont know about you but in the summer i use my ac so might as well not waste the extra cold coming off the condenser
-1stGenRocks- 95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's plans: bastard 20g, water/meth injection NO FMIC |
why not shove ice right inside the intake,which would make the air real cold,lol
2000 GRAND PRIX GTP RED 14.345 @97.8mph ubend delete 3in jimmyC downpipe magnaflow high flow cat Joeflo CIA (made it myself) free bypass mod 3.4 pulley from zzp Gates premium belt 1 step colder plugs zzp PCM ss 409 xl turbo mufflers |
I have heard of people taking bags of ice and putting them on the CAI before the race, and then just before they take it off.
For Sale 98 Eclipse GS, 5 spd |
IC pipes werent made to transfer heat though, so it doesnt do a whole lot
![]() USing the AC as an intercooler definitely isnt for everyone. But when you have 800 wheel hp and need a lightweight compact IC solution, it can be the way to go. The expense and complexity often is overlooked when its a necessity on a full race car. Of course running methanol would have taken car of that, but thats a whole new can of worms.
95 Eclipse GS: OBX Full Exhaust System, OBX Headers, OBX Short shifter, OBX Spark Plugs & Wires, 17' MSR Rims w/ Wanli tires 96 Eclipse GS-T : K&N Filter w/ Hardpipe, UICP & LICP, Greddy Type S bov, Greddy Boost Gauge Hala Madrid! |
Again, its not going to do anything. A piece of pipe is a terrible heat exchanger.
yeah,that doesn't sound like it would do that much
