Old 03-18-2004, 11:24 PM
thebigbr thebigbr is offline
wheels/ thumping
hey,
just noticed today that my passenger side wheel sticks out farther that the driver side. i find that kina odd. just wondering if this should be a concern or what? i dont have any spacers or anything.
also when i turn to the right i get a thumpping noise comeing from underneather my jeep, and the fater i make the turn the harder and faster the thump. it doesnt do it when i turn left but i do feel some roughness. i guessing its the u-joints, could it be anything else?, and if it is the u-joints which one? could this affect my handeling?
thanx
Old 03-19-2004, 08:50 AM
Dale Aeppli Dale Aeppli is offline
Re: wheels/ thumping
Originally Posted by thebigbr
hey,
thanx
HI, AGAIN IT SOUNDS LIKE YOU HAVE A BAD U JOINT ON THE PASSENGERS SIDE. CHECK BY JACKING THE FRONT END OFF GROUND BOTH SIDES, ROTATE EACH TIRE BACK & FORTH IF YOU HAVE BAD U JOINTS YOU HEAR CREAKS AS THE WHEEL TURNS. CHENGE THEM BEFORE THEY BREAK & WRECK YOUR FRONT AXLE. DALE
[email protected]
Old 03-19-2004, 09:18 AM
dumbplumber dumbplumber is offline
i had the same problem with my 88. i first thought it was the wheel bearing. so i jacked it up and checked, no visible sign of being bad also no unusual movement in the bearing so i pulled the front axel and found the ujoint to be in good shape. i did some further checking and found out the wheel bearings on the jeeps sometimes act like a ujoint. i checked again and still couldn't find anything that i could pin down as wrong with the wheel bearing. After a discussion with a friend of mine who happens to be an instucter for automotive at the local college. He said it sounded like the wheel bearing and also said that with jeep having a sealed wheel bearing assembly you cannot always tell when it is bad. So I spent the $85.00 on the new assembly. Problem gone!!
Old 03-20-2004, 08:47 PM
hey,
thanx for the imput. but.. i took a look today under my jeep and i ony have two u-joints, that i can see, one at the rear diff and one at the t-case. those joints wouldent have that effect would they?? so that would mean that the wheel bearins are gone, right??? because i have no right u joint, it looks like my my whole front axle is one piece
thanx
i know im annoying ha ha
Old 03-23-2004, 02:33 AM
never mind i am a complete idiot, disregard anything i said
"sometimes you just have a blonde moment"
Wheel width/offset help Rooster32 Interior | Exterior | Appearance 0 04-05-2010 10:45 PM
Steering Wheel Repair JDatx512 Tacoma 0 03-30-2009 12:55 PM
96 Town Car: Wierd Prob w/ Steering Wheel Button(s) LieutenantCracker Town Car 6 03-05-2009 12:24 PM
Problem with the steering wheel Ennar Aveo 5 03-03-2009 09:11 AM
'98 Sentra rear wheel thumping noise lrac Sentra | 200SX (USDM FWD) 2 07-09-2007 07:02 AM
