Old 03-18-2004, 07:47 PM
mike mahoney mike mahoney is offline
Power Steering Pump
I Also Have A 2000 Silverodo 1500 Ext.cab With 40000 Miles. I Replaced The Power Steering Pump Twice Within 800 Miles. It Seems That When You Turn A Hard Right It Snaps The Shaft In The Pump. We Are Still Trying To Figure Out Why This Happens. Of Course The Dealer Doesn't Want To Know Anything About The Problem. Does Anyone Have Any Suggestions. I Will Try Anything.
Old 03-18-2004, 09:31 PM
desertmike1 desertmike1 is offline
Re: Power Steering Pump
I'm thinking your pump is going to hydraulic lock, and the engine via the drive belt is snapping the shaft.
At this point one might lean towards the hydraulic proportioning valve inside the Rack&Pinion?
I always thought that the power stearing pump it-self had built in over pressure protection, but sense you tried two differant pumps this might not be the case.
When you figure this one out let us all know.
-Mike
Old 03-18-2004, 11:23 PM
homefree's Avatar
homefree homefree is offline
I'm not sure but i think i just seen some thing on this about a recall, check it out. Could save you some work and a little cash.
How To R&R 1998 Grand Caravan Power Steering Pump CarBob Caravan | Voyager 0 04-04-2010 10:59 AM
Problems with Acceleration and now Power Steering dbhynds '01-'05 Civic 5 01-06-2010 07:41 AM
92 Cutlass Supreme Power Steering Hose Mikey_G Cutlass Series 4 11-23-2009 01:47 PM
2000 PA Power Steering Fluid Check buickultra2000 Park Avenue 2 11-12-2009 10:12 AM
92 deville 4.9 Power Steering Pulley sheered / fell off and destroyed belt! 92Deville Deville 1 06-03-2009 06:51 PM
