Old 03-18-2004, 04:29 PM
jelly jelly is offline
help with radio
How do you get the radio out of a 91 escort? Thanks
Old 03-18-2004, 10:20 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Re: help with radio
Not sure about a 91, but I know my 94 requires a special tool. Look at the elft and right sides of your radio... if you see two small holes, one above the other, on each side, then you know you need the special tool. Some brilliant person may speak up and tell you a way to rig something up though.
Old 03-19-2004, 01:01 PM
jats03 jats03 is offline
There should be a hole in each of the 4 corners of the radio, you can buy the tool at any auto part store or stero store or you can use 2 paper clips thats what I did. But all four holes have to be pressed in at the same time.
Old 03-19-2004, 11:01 PM
Re: help with radio
Thanks. That is what I thought.
Old 03-20-2004, 11:27 PM
arcade84_2003 arcade84_2003 is offline
Send a message via Yahoo to arcade84_2003
Re: help with radio
it's easier if u use 2 wire coat hangers....that's what i did
Old 03-23-2004, 12:06 AM
88EscortWagon 88EscortWagon is offline
i have worked on a lot of fords... the easiest way to get the stereo out is definitely to buy the right tool, it might set you back a couple of dollars (tops) but it will save you from a lot of headaches. trust me, ive done both and the store bought tools make it easy!
Old 04-09-2004, 03:42 PM
Jet-Lee's Avatar
Jet-Lee Jet-Lee is offline
Banned
Send a message via AIM to Jet-Lee Send a message via Yahoo to Jet-Lee
Re: help with radio
I jus used nails, or those stakes you use for your christmas lights? Anything that fits in the hople pretty much works, if u got 4 of 'em...
Please help with radio code Daniella Fiesta 2 05-11-2006 09:25 AM
need help with radio/wiring Black Knight 00 Eclipse 2000+ 3 02-18-2005 07:01 AM
Help with Radio Wire Diagram RayeAlmighty Interior | Audio | Security 4 01-29-2005 12:06 AM
newb, need help with radio zidacramant Taurus | Taurus Wagon 0 12-27-2003 04:07 PM
Need Help with Radio Codes BertZ3 Accord/TSX/Accord Hybrid 4 03-07-2002 08:23 PM
