Go Back   Automotive Forums Car Chat > Cars in General
Old 03-18-2004, 04:38 PM
alphalanos alphalanos is offline
Removing Emblems
I want to remove the emblems from my hood and trunk and also the dealer's decal on the back of my car. They are all the stick on type. As you can imagine, I dont want to harm the paint, so how could i go about this?
Old 03-19-2004, 11:40 AM
mcpbw mcpbw is offline
Send a message via AIM to mcpbw Send a message via Yahoo to mcpbw
Re: Removing Emblems
You could either use a heat gun (just don't leave it on too long) to loosen the adhesive then clean with goo-gone or you can try a steamer. It seams like there are a few different adhesives they use so you may have to try a couple different methods. Just remenber once removed that there may be a slight color difference (lighter or darker) but a good polish should even it out with the surrounding area.
Hope this helps
Eric
Old 03-19-2004, 02:54 PM
heat gun as in hair dryer?
Old 03-19-2004, 04:23 PM
a good hair dryer may work / a heat gun just gets hotter but basically the same idea
Eric
Old 04-03-2004, 03:38 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Car emblems are always just glued on. They have little prongs/pegs that hold them in place. Sometimes you can get access to the prongs/pegs through the inside, like the inside of a trunk. Just cut off the prongs then push the pegs out with a screw driver.
03 Mustang GT's have pegs that hold it inplace with the adhesive. Those emblems are easy to remove, just pull real hard. Or pry it with a flat head screwdriver.
What about the hole though? Do you plan on filling it and paint?
-Mike
Old 04-03-2004, 04:00 PM
yes the pegs. well i left the two emblems on but managed to remove the dealer sticker, and the make/model badges. so for now the ones with the pegs are staying unless i can get the areas repainted a close enough match to my car, if so i would also get my antenna shaved and pinstripes taken off.
Old 04-05-2004, 03:41 PM
mike@af's Avatar
You can peel the pinstripes of usually just like the dealer sticker but the paint there will either come off with the stripes or will be darker there since paint does fade.
Or are you talking about real pinstriping??? Like on Hot Rods?
-Mike
Old 04-06-2004, 04:30 PM
no theyre just the sticker type.
Old 05-01-2004, 12:15 AM
4ss4s1n's Avatar
4ss4s1n 4ss4s1n is offline
Send a message via Yahoo to 4ss4s1n
If you dont want anything to harm your paint,or just too lazy.Spray on some WD-40.That will make it so you just peel or pull it off and there will be no residue.All you need is patience,just spray it all over and leave it for a few hours or all night.You'll enjoy the benefits.
Old 09-21-2006, 08:02 PM
Mklangelo Mklangelo is offline
Interesting... I'll give it a go.
Removing Emblems cashew02 4Runner/GX470 0 07-18-2005 09:59 AM
Removing Emblems from a 2003 S-10 Pickup Trucker666 S-10 4 10-16-2004 11:08 PM
Removing Emblems SilverSpec-V Sentra | 200SX (USDM FWD) 27 04-28-2004 10:49 AM
removing emblems sweetwhiteCAV Cavalier 9 07-13-2003 10:45 PM
Removing Emblems Hatchin '88 - '91 Civic | CRX | Wagon | Shuttlee 18 02-17-2003 08:17 PM
