Old 03-18-2004, 12:14 PM
JMJEREMIAH3239 JMJEREMIAH3239 is offline
Rad Sludge
My rad has been flushed and antifreeze changed a couple times over the years. It seems like there is always some tan colored coating around the
neck and cap.....any ideas where its coming from. I have a '96 3.8 Winny.
ps. its been doing this for years.
Old 03-18-2004, 02:53 PM
rodeo02 rodeo02 is offline
A lot of it is just minerals coming out of solution from the tap water shops use in the 50/50 mix, normal corrosion from the cast iron engine block & aluminum components, or sealing materials. Just make sure it doesn't get oily or you dont start loosing coolant- signs of a head gasket failure. Swapping out the coolant is a smart thing to do regularly. Many people totally neglect this.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
1997 windstar mysterious brown sludge in cooling system FLAWIND Windstar 11 07-16-2012 08:53 PM
Rad fluid too hot, maybe fan sucks PLUS bleeding rad question? dremen Taurus | Taurus Wagon 4 10-16-2010 07:34 PM
98 Sienna - Sludge or no Sludge ozzie32 Sienna 5 04-27-2006 02:24 PM
Possible rad problem/rad fan 3gz Cavalier 1 01-04-2006 12:34 PM
Confused...temp sender in rad + another in lower rad hose? BwanaD Cherokee 0 09-24-2005 09:08 PM
