Old 03-18-2004, 01:07 PM
mint567 mint567 is offline
Motor oil and filter
What type of motor oil should I buy? I want to get the synthetic oil. I was wondering what were some preferences on brands and weights considering my engine has high mileage, the higher weight would be better or just stick to the 10w30 or 40. Also what about the oil filter? What brand oil filter is better than one that say a quick lube place would put in? Thanks for any input.
Old 03-18-2004, 02:16 PM
RattlesnakeGST RattlesnakeGST is offline
Mobile 1 10w-30 Synthetic with a Mitsubishi OEM oil filter.... Either that or Amsoil... Been using that combo since ive had the car.... Got rid of that annoying lifter tick when i first bought the car..
Old 03-18-2004, 07:51 PM
metalhedskater's Avatar
metalhedskater metalhedskater is offline
Send a message via AIM to metalhedskater
Re: Motor oil and filter
i use penzoil 5w3o
Old 03-18-2004, 08:10 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Nobody likes to hear that I buy whatever is on sale, like $0.99 Pennzoil 5w30. I use NAPA gold oil filter... next time I might stop by the dealer and buy OEM. Quantity over quality for me.
Old 03-18-2004, 08:16 PM
anarchy1114's Avatar
anarchy1114 anarchy1114 is offline
Send a message via AIM to anarchy1114 Send a message via MSN to anarchy1114 Send a message via Yahoo to anarchy1114
i use penzoil 5w30 with fram oil filters. i used to use redline oil and k&n oil filter but that was getting way to expensive. so i now go the same way as JoeWagon, quantity over quality.
If it has tits or tires it will give you problems, but atleast you can fix the problems with the tires
2007 Trailblazer - stock
97 GS-T -> lots of mods
98 GS ->total loss, now being parted out
Old 03-18-2004, 09:12 PM
I went to PepBoys one day.. and case of Mobil 1 wouldnt ring up.. So she punched it in and it rang up $11 for a case of 6 quarts... So being the dishonest bastard that i am.. I went to the cash machine then went back and bought 3 more cases.. at $11 each.. Instead of the usual $30 a case.. And have acquired a pretty impressive stockpile of Mobil 1.... Yes.. im aware of bad Karma.. But ive got more than enough points stocked up to cover it
Old 03-18-2004, 09:34 PM
95_GSX's Avatar
95_GSX 95_GSX is offline
Send a message via Yahoo to 95_GSX
i run amsoil 10w40 with an amsoil filter. Quality over Quantity
Got AWD?
Some people buy super cars, other build them
----Click It, For Mods and Pics----
'95 Mitsubishi Eclipse GSX - For Sale
'05 Volkwagen Golf GLS TDI - My daily driver
'03 Ford Excursion 6.0L PSD 4x4
'13 Ford F150 FX4 SCREW 4x4 3.5L EcoBoost
'08 Buell 1125R
'83 GMC Sierra Classic K2500 4x4 - Future Cummins Swap
Old 03-18-2004, 10:04 PM
How much is amsoil anyway?
Old 03-18-2004, 11:04 PM
95ClipseGS-T 95ClipseGS-T is offline
Send a message via AIM to 95ClipseGS-T Send a message via Yahoo to 95ClipseGS-T
for a new engine what would yall recomend.A freind of mine has a 87 monte carlo aerocoupe with a new 383 stroker motor and he runs Havolin or Moble 1 but not synthetic. he says its not all that much better for the price diffrence, as long as you change your oil every 3k miles
95 GST
5 Speed
Cone Open airfilter
Custom 3" Turbo Intake
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 03-18-2004, 11:39 PM
kjewer1 kjewer1 is offline
AF - Advisor
I run a decent regular 10-30 type oil, like penzoil or whatever. But do NOT skimp on the filter! Fram is among the worst there is. The best ones are OEM (~4 bucks) and Pure1 (~5 bucks). Cheap oil is fine, but cheap filters will cost you turbos and motor bearings over time. Then you realize you didnt save all the much...
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-19-2004, 12:03 AM
dsmodder dsmodder is offline
Send a message via AIM to dsmodder
cut a fram filter in half and then cut a oem and a purolater or whatever it is. the fram is thinnest or shittiest, i think purolater then oem i donno. fram is shit they just put more into advertisement... see for your self and cut some open.
Old 03-19-2004, 10:36 PM
95_GSX's Avatar
just under $6 a quart.
Got AWD?
'08 Buell 1125R
Old 03-19-2004, 11:45 PM
EVOclipse EVOclipse is offline
Send a message via AIM to EVOclipse
i use 10w-40 synthetic as well...living in FL oh yeah watch that ticker go to 107k..lol
Old 03-19-2004, 11:54 PM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
Re: Re: Motor oil and filter
Yes Fram is complete and udder shit. I have personnaly seen Fram filters on an engine causing the oil pressure light to come on becasue the pressure was under 5psi at idle.
OE filters for sure, Ill be running Mobli1 synthetic once I get my engine broken in.
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
Old 03-20-2004, 12:19 AM
whyte Gsr b0i's Avatar
whyte Gsr b0i whyte Gsr b0i is offline
Send a message via AIM to whyte Gsr b0i
you gotta know history on the Oil.. cant just buy what they say.. I'd personally go with castrol synthetic.. castrol was previously only used in top fuel and funny cars.. untill castrol released a street formula... ~GTX~ which happen to be very similar to the formula use in top fuel.. except they added something to make it recondition used and dried out seals.. GTX is fine i just use senthetic because its a turbo talon.. and it doesnt break down as quick and gtx.. filter.. hmm i like to use FRAM.. there are different type i forget what its called.. but its about 10 dollars.. made for synthetic uses..
97' talon Tsi fwd..
Rebuilding the engine.. should be running atleast 14.5 stock when i get that whip back together
'94 accord Lx coupe swaped ta Vtec...
1/4: 15.1
MODs: custom CAT.. VERY highflow.. Theres no Replacement for displacement.. and add me.. you can have times liek this too
90% driver 10% car
Nom'tawkin'bout
