Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > Performance
Performance Discussion about performance modifications and issues.
Old 01-07-2002, 01:38 AM
khughes khughes is offline
Apexi AVC-R Setting
Guys,
Just searching through the settings on the Apexi AVC-R that i got with my car, i must say that i have tried reading the manual and it is a little over my head so far!.
One thing i did notice though is in settings, ETC, Car Select, SPD the setting is set to 4 and not 2 as it states in the manual (all other nissan's), i know the speed readings do not seem to be accurate and i just wanted to double check before changing the setting.. don't want to blow the car up..
Also as far as i know the car is running 0.7bar of boost, how would i increase that (97 GTR) in the AVC-R you need to set boost and Duty which in the manual equals solenoid valve duration divided by total solenoid valve operation duration times by 100.
How do i work out the durations? obviously i cant count to 16ms
Can anyone help? Thanks
Old 01-09-2002, 09:53 AM
YCEE YCEE is offline
If you are trying to run 0.7bar of boost, you don't need to turn on the boost control (just set it to OFF). I am running 0.8bar with 35% cycle and 1.0bar with 50% cycle. I think it is almost the same on all standard GTRs.
Old 01-15-2002, 06:08 AM
zapf zapf is offline
Just keep in mind that with the AVCR turned off, your the boost won't come up as quick as well.
Cheers
Zapf
Old 01-15-2002, 06:01 PM
so if i turn the boost controller to off, what is controlling the amount of boost? the wastegate?
(i am also trying to figure out where abouts the boost controller solenoid fits in with the turbo's)
Thanks
Old 01-16-2002, 01:42 PM
If you bypass the solenoid, the boost you are generating will directly press on the spring of the wastegate, thus causing the wastegate to open more, hence less boost.
Apexi AVC-R type R for sale calvintys 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 0 05-19-2003 11:40 PM
Apexi AVC-R setup! Tricky-Ricky 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 05-06-2003 02:08 PM
Apexi AVC-R boost controllers speed shop RX-7 0 11-27-2002 03:32 PM
Brand new Apexi AVC-R for $420 Rich J Classifieds 4 11-02-2002 06:29 PM
Brand new Apexi AVC-R for $420 jolivo69 Classifieds 0 06-21-2002 02:10 PM
