Old 03-18-2004, 08:15 AM
msgrntalon msgrntalon is offline
Send a message via AIM to msgrntalon
Question Aftermarket headlights?
Can anyone tell me where i can find some aftermarket headlights for my 94 eagle talon. my stock ones just don't cut it. i am looking to start throwing some money into my car and replacing the factory (dirty looking) headlight lenses has to be done.
Old 03-18-2004, 09:57 AM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Aftermarket headlights?
first try cleaning your current ones use either metal polish/cleaner or rubbing compound i used some foaming interior cleaner one mine and it worked great
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 03-19-2004, 08:16 AM
Just a regular metal polish? it is cool if it will work on the plastic headlight lenses. I will probably try it today. Thanks man. I hope it works.
Old 03-19-2004, 12:49 PM
MrZ's Avatar
MrZ MrZ is offline
msgrntalon;
You can buy plastic polish at most auto parts stores, but fact is it is very close in grit to fine polishing compound, and costs quite a bit more.
My headlights were pretty dinged up when I finally got around to polishing them up. I actually used fine grade steel wool first, then medium grade polishing compound, then fine polishing compound (also called rubbing compound).
They look much better, but the heavy dings are still there. It sure beats getting new ones though, standard replacment headlight housings run about $200 each.
Mark
Old 03-19-2004, 02:07 PM
Thanks mark for the help. i will probably try that when i get home.
Old 03-22-2004, 07:44 AM
jp91tsi's Avatar
jp91tsi jp91tsi is offline
Send a message via AIM to jp91tsi
i recommend Mother's Aluminum polish, can be picked up at any AutoZone/Pep Boys/ auto stores
