Go Back   Automotive Forums Car Chat > BMW > 7 Series
Old 03-18-2004, 12:04 AM
charlesotis46 charlesotis46 is offline
How to remove rear seat for battery 93 740i
It is not electric. Battery dead. Never replaced. Have 165k miles..Question - when tried to start - trans program message came on. Have never had any trans trouble, no noticeable shifting problems, etc. Jumped car - started immediately - drove around - no message ever reappeared - simple electrical screw up? but still need to find out how to get rear seat out. Hopefully only battery problem and not alternator.
Old 03-18-2004, 04:53 AM
libertylover libertylover is offline
Re: How to remove rear seat for battery 93 740i
Piece of cake!
0) Make sure you know your radio code!
1) Pry off the little plastic cover located on the rear seat on the passenger side.
2) Using a 10mm socket, remove another little plastic cover under the first one.
3) Using a 13mm socket, disconnect the negative lead of the battery at the place provided-it's obvious.
4) Lift straight up on the rear seat and viola, there is the battery. The thing on the driver's side is the rear power distribution center. Notice it actually has some fuses, so this would be a good time to make sure all of the fuses are OK. It's also a good time to collect all of those coins and ink pens that have fallen out of passenger's pockets over the years, not to mention finding the source of that yucky smell you sometimes get a wiff of :-), just kidding I hope.
5) After you put the seat back together, enter the radio code so the radio works again.
A couple of other notes. The battery for a BMW 7-series is big and heavy. For some reason, wierd electrical things happen (like the false transmission error) when the voltage is low, so get the right battery. Translation: it'll be expensive as far as batteries go.
Also, it's in the passenger cabin with you and it has a plastic vent tube to give the ???fumes??? from the battery a place to go besides inside the cabin with you. When you remove the battery, notice carefully where this vent tube goes so you can put it back in the same place.
Old 03-19-2004, 08:36 AM
Thank you for your help!
