Old 03-17-2004, 10:16 PM
chickluva chickluva is offline
Lightbulb new obx exhaust = check engine light
installed new OBX exhaust on 92 acura integra ls, now check engine light comes on about 10 minutes after driving, i can reset it by turning ignition off then back on but light comes back on after another 10 minutes.
Old 03-17-2004, 10:25 PM
defmusik's Avatar
defmusik defmusik is offline
you probably forgot to hook the sensor back up to the cat..
(Yeah there isn't much yet)
=-= 97 Civic EX VTEC =-= AEM CAI =-= Dynomax Catback Exhaust
=-= Dual Halos =-= Carbon Fiber Altezzas
=-= Aftermarket Alarm =-= Alpine 9825
=-= (Shitty) Sony Xplod 6x9 in the rear (50watts RMS)
Old 03-17-2004, 10:26 PM
Re: new obx exhaust = check engine light
the sensor is on the header not on the cat
Old 03-17-2004, 10:35 PM
Hybrid_Sol Hybrid_Sol is offline
Re: Re: new obx exhaust = check engine light
...or exhaust manifold
So was the problem a disconnected O2 sensor, or is the light still coming on?
All else being equal, there's no replacement for displacement, however all else is not equal.
1994 Del Sol
B18C
LSD
DC Sports Exhaust
Old 03-18-2004, 11:14 AM
no.... the light is still coming on and all o2 sensors are hooked up and ready to go, i think that between having a cold air intake and a high flow exhaust it is probably running to lean, and the ecu is sensing this i think ineed to get more fuel into the injectors now.
Old 03-18-2004, 08:08 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
how about you check the codes.....there will be a red light that blinks count how many times it blinks and check it up online or in a car specific manual to see what the codes mean
Note: it sometimes will display more than 1 code there will be a gap inbetween them
2002 Acura TL Type S
1991 Honda Crx Si
Old 03-22-2004, 10:24 PM
how do you pull codes off the Ecu my ecu dous not have any LED's on it.
Old 03-23-2004, 01:00 AM
liquidflame8 liquidflame8 is offline
no way the engine would run lean becuase of an intake. exhaust has nothing to do with the a/f mixture.
Old 03-23-2004, 01:30 AM
rubix777's Avatar
rubix777 rubix777 is offline
Send a message via AIM to rubix777
sometimes if you mess with the O2 sensor they don't read correctly. Might want to clean them off before you put them back in.
Old 03-23-2004, 05:27 PM
i took the O2 sensor out and cleaned it and reinstalled it, still the light persists. i'll probably take it Autozone and have them look at for free, now i'mbeing told that the MAF sensor is probably tripping due to the intake and exhaust mods, never had any problems with my 93 Vigor GS so this is starting to pi*s me off.
