Old 03-17-2004, 11:00 PM
95eclipse-gsx 95eclipse-gsx is offline
Post swaybars and strut bars???
hi guys...
i just want to know.. wat does a swaybars do in ur car??? and wat does a strut bars do in the car???
Old 03-18-2004, 12:16 AM
Chavez408's Avatar
Chavez408 Chavez408 is offline
Send a message via AIM to Chavez408 Send a message via Yahoo to Chavez408
Re: swaybars and strut bars???
dont strutbars help your corner ability? or am i wrong? im just thinking from the top of my head so im not very sure if im correct
- Its Micheal Jackson! and his black again!!! YAY!!!!!!
LandoAWD - My rolemodel!! why? because his a bad ass! beache..! and he will kick ur A$$!!
Originally Posted by Delerious93integra
and if DSM's are so great.. then why doesn't everyone own one
^^^ WOW!!! ^^^
Old 03-18-2004, 07:30 AM
kjewer1 kjewer1 is offline
AF - Advisor
Sway bars, or antiroll bars control the side to side movement of the body. They fight the car leaning to the side as you turn. AWD dsms have them form the factory. Many poeple upgrade to thicker ones.
Strut bars connect the tops of the strut towers together to prevent movement from the forces acting on the struts when cornering. This is good for 1g, but 2g doesnt use the same type of suspension. The 2g firewall is also VERY close to the shock towers, so a front strut bar doesnt do as much as it does on a 1g. Both cars will benefit greatly from a rear bar though. Being hatches, there is noting to triangulate the rear and keep the body from flexing. The bar will stiffen it up.
I never bothered with a rear strut bar because the roll cage I have to run will include a much stronger version anyway. If you do get one its important that its strong and cant flex. Most brag about how strong the bar is, while the bends and angles in the mounting plates will allow tones of flex. Dont waste your money on a shyte design.
Sway bars will help everyone regardless of suspension mods. I rode in a friends 2g AWD with no suspension mods other than swaybars and cornering was very flat. In my case I'm going to use them to corner flatter without increasing my spring rates, which would hinder my launching abilities at the track.
Hope that helps.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-18-2004, 12:35 PM
daniellebrian7's Avatar
daniellebrian7 daniellebrian7 is offline
anyone know were you can buy a cheap rear sway ?
Old 03-18-2004, 02:21 PM
RattlesnakeGST RattlesnakeGST is offline
Strut Bar=Hides the shitty build quality cause things wont rattle half as much.. Best investment so far
Old 03-18-2004, 11:05 PM
anybody know i site on were to get cheap rear sways at ?
Old 03-18-2004, 11:08 PM
95ClipseGS-T 95ClipseGS-T is offline
Send a message via AIM to 95ClipseGS-T Send a message via Yahoo to 95ClipseGS-T
procarparts.com
95 GST
5 Speed
Cone Open airfilter
Custom 3" Turbo Intake
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 03-18-2004, 11:36 PM
AF - Advisor
If "cheap" means it will jsut flex with the car, save the money for something else.
Kevin Jewer
