| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
What does vtec actually do? i mean yeah i know i need a DOHC VTEC but what exactly is it? please tell me 'cause i wana learn.
Re: What is vtec exactly?
you know how when you get a car without vtec if you want to get a really aggressive cam it starves at low rpm and sucks? when you have vtec it's like having 2 stages of cams. one that is optimal for low rpm and then one that is optimal for high rpm. so at a certain point the rocker arm switches to the higher rpm lobe, hence vtec. sohc vtec only has vtec on the intake part of the camshaft and the dohc's have it on both intake and vtec. that's y their better. they have more tunability.
DOHC vtec
SOHC vtec Click either of those and you'll learn more than you ever wanted to know. In a nutshell, when vtec engages on a dohc engine the valves lift higher letting in/expelling more air and the computer sends more fuel, for a bigger bang. In real life (on my engine) the engine gets really loud and it goes faster. Last edited by Ricochet; 03-19-2004 at 03:44 PM. |
Vtec does'nt add all that much power, but when you want to pass some asshole on the feeway/highway, and want to do it fast, it helps to drop your car in thrird, and just slam on the gas... you'll be doing 90-100 mph before you know it.
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors). To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods. check me out on: http://www.cardomain.com/memberpage/515191 |
ok killah for one thing i noticed that you have a 4 door honda accord lx and it's obviously a 4 cylinder. do you even know anything about cars? you obviously have an automatic beacuse that v-tec isn't just the droppping of the gear that's your car downshifting. my lord. . . .
Re: Re: What is vtec exactly?
and to answer the first question, go to this site, they got good info. http://www.leecao.com/honda/vtec/whatsvtec.html make sure you click around on all the other links on the left side to learn more.
Stock 1992 Civic DX hatch |
Re: Re: Re: What is vtec exactly?
Re: Re: Re: Re: What is vtec exactly?
http://www.leecao.com/honda/vtec/ "The lack of cam profile changing for exhaust valves is the primary difference between DOHC VTEC and SOHC VTEC engines. Since the exhaust valves in a SOHC VTEC engine behaves just like a non VTEC engine, only the intake valves will be discussed below. " -- reference can be found here --> http://www.leecao.com/honda/vtec/sohcvtec.html for h series motors, here's some skunk2 cams for the h22a You can see the VTEC lobes on both intake and exhaust camshafts. http://www.coximport.com/store/sk-305-05-0200 http://cgi.ebay.com/ebaymotors/ws/eB...tem=2468177333 this one is for non-VTEC prelude notice there are no VTEC lobes, just the standard lobes. Last edited by rubix777; 03-24-2004 at 08:03 PM. |
ok guys, so i found the magazine. it was actually the Febraury issue of Power Pages, not honda tuning mag, sorry. i tried to find the exact same dynos online, but i couldn't find those.
The first graph shows the power of the conventional Ls engine and then the VTEC frankenstein engine. Both engines were outfitted with an intake, exhaust, header, and cam gears. The plain ls engine put out about 147 at the wheels. the frankenstein engine put out about 177 at the wheels. Then they showed turbocharged variants of the same combination. At 10 psi of boost the VTED-headed integra ls engine generated 58 horsepower more than that the same block running an LS head. just so you guys know, the turboed lsvtec was making like 270 at the wheels. hope this helped killah_xft who is obviously retarded and shouldn't be able to post here anymore for saying such stupid comments when he doesn't even have vtec.
Re: Re: Re: Re: Re: What is vtec exactly?
Well Ahhh errrr ![]() That should explain it
