Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 03-17-2004, 04:29 PM
jody3x3 jody3x3 is offline
Send a message via ICQ to jody3x3 Send a message via AIM to jody3x3 Send a message via Yahoo to jody3x3
Exclamation top speed of a 1996 maxima
i have had my 96 maxima for 4 years. i have only had v8s since i was 16. i am very imppressed with the perfomance i get from my 5sp. Max. I never go to the track, but i smoke ALL cars in my class on I-285 in Atl. a dealer told me the maximas horsepower is truly underated, for those who dont have maximas. and i believe it. does anyone know what top speed is for the 1996 year? mines is governed at 120mph, but i can easily bypass it by diconnecrting the speedometer. I get 120 in 4th gear at 4000~4300 rpm. when i disconnect the speedometer hit 120 in 4th, then shift to 5th, it is another world. i was racing a ZX9 ninja (just 4 fun) to see how fast i was going, he said i was doing at least 145mph. I burnt 2002 Volvo S80, 2000 gran prix gtp or gtx(whatever), 325 bimmer, 2003 dodge hemi truck, ran with a 96 impala SS(top end)and many others mention. all i did was take out the stock air box, and put a cone air filter in. a full tank used to give me 388 mile, with that new air filter i get 410~420 mi per tank, and when its raining i can spin thru 5th gear(no lie) i always catch 2nd, and sometime 3rd. whats the real deal with this car? its it truly underrated, and what the top speed ungoverned?
[b]AND WHY IS THE INSURANCE SO DAMN HIGH
Old 03-17-2004, 05:23 PM
ogparjay ogparjay is offline
Re: top speed of a 1996 maxima
~ maybe 155.... i dunno... try it out some where safe
Old 03-17-2004, 06:50 PM
also my girl has a 2001 sentra, for full coverage, mines is 3x the amount of her car
Old 03-17-2004, 08:22 PM
wunfstmax wunfstmax is offline
i think its like 152 or sumthin like that
Old 03-17-2004, 08:49 PM
MaxGle MaxGle is offline
Send a message via AIM to MaxGle
Well this is what i heard that on the 5sp gxe max u cant go above then 120mph but if you have the Se 5sp then u will hit about 140-145's.. or thats what i heard, also you said somthing about "new air filter i get 410~420 mi per tank" well i wanna know what new air filter it is i mean like stock or upgraded or whatever lse it might be. If you can post the details on my forum and give me a link to this filter if possable.. thnx later
Old 03-17-2004, 09:23 PM
i will have to get back to u on the name of the filter. but thats a lie on the 120. i get one 120 in 4th gear and i have a 96gxe. it only slows down because of the governor. i can easily get 130mph in 4th gear stock. the only thing i have to read is my RPMs
Old 03-17-2004, 10:48 PM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
I saw on a dyno that a 95 se would go no higher than 152 mph and that's without wind factor. probably 140-145. SE's and GLE's are not governed. and gxe's can have the governor removed by
1.Disconnect negative battery terminal.
2.remove ECU cover from passenger side footwall.
3.Loosen bolt in center of main ECU connector.
4.Unplug main ECU connector.
5.Remove snap-on plastic cover from ECU connector.
6.Locate PINK wire with BLUE stripe. (this wire is located on the right half of the connector when plugged in)
7.Cut PINK/BLUE wire.
8.Reassemble ECU connection.
9.Reconnect negative battery terminal.
i didn't know disconnecting the speedo would work too but with the ecu mod you can watch the speedo hit 140+. unfortunately it causes you to throw a CEL.
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
Old 03-18-2004, 07:14 PM
Caracicatriz's Avatar
Caracicatriz Caracicatriz is offline
My SE is governed. It stops at exactly 118mph. I went 125 once going downhill. It accelerates so fast to 118 and just stops. I hate it.
Old 03-18-2004, 07:54 PM
BP2K2Max's Avatar
are your sure it's an SE. I'm positive SE's are not governed cuz in my 95 se I went 136 while racing a 3.2 CL type S.
BP's Rides;
Old 03-19-2004, 10:15 PM
WDzSin WDzSin is offline
Send a message via AIM to WDzSin Send a message via MSN to WDzSin Send a message via Yahoo to WDzSin
well my 3rd gen tops out at 125 governed amd i know it can hit more than that. at least 135, 140
Old 03-19-2004, 10:30 PM
joeB joeB is offline
When we had our 96 GXE 5 speed, it would rush to 120 then the
gov. kicked in.. SE five speeds arent supposed to have a gov. and
best Ive read for stock is 143 MPH.. Maybe his SE is a auto. thats
why it wont go any faster?
Old 04-25-2004, 06:58 PM
dipankar06 dipankar06 is offline
Anyone know the top speed for a 98 GLE auto. I once did around ~115 MPH but had to stop due to traffic.
Old 04-25-2004, 07:35 PM
Re: Re: top speed of a 1996 maxima
I'm very sure it's an SE. Got it brand new in 97. It's an Automatic though.
Old 04-26-2004, 09:52 AM
Tyrexx's Avatar
Tyrexx Tyrexx is offline
Send a message via AIM to Tyrexx
my 97 auto has been to 135. It's alot easier if you have OD off then turn it on at 120mph (about 6300rpms)
