Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 03-17-2004, 01:47 PM
greddyteggy's Avatar
greddyteggy greddyteggy is offline
Send a message via AIM to greddyteggy
Weird BOV sound
I got my turbo installed and running, my only question now is that my HKS SSQV makes a fluttering sound when shifting under low boost and sometimes with high boost. Should I tighten or loosen the BOV or is this normal?
Old 03-17-2004, 09:05 PM
quick95civic quick95civic is offline
where is your setting now. I have mine with about 4 threads showing between the bolt and the adjustment nut and it does sound like that sometimes under low boost when I let off the gas slowly. I have the same bov as u and it makes several different sounds depending on boost levels and how fast you shift.
Old 03-18-2004, 03:55 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Re: Weird BOV sound
That is the sound that a car makes when the BOV is not working or does not have one. It is called compressor surge. As you know, when you let off the gas, it closes the throttle plates, but the turbo is still trying to cram air into the engine. Well when this happens the air has only one way to flow, and that is backwards. compressor surge is reall hard on a small turbo with floating bearings. However, a large shaft turbo or a ball bearing turbo is does not matter.
Get your sneeze valve set right and it won't happen.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 03-18-2004, 05:25 PM
Re: Weird BOV sound
How do I go about doing that? Do you mean adjust the BOV?
Old 03-18-2004, 07:03 PM
if you are actually getting compressor surge make sure you have the BOV connected to a good vacuum source after the throttle body. If your hose it connected right then your BOV might actaully be adjusted too tight. To loosen it up you need a 10mm open end wrench, there is a nut that locks the adjusting bolt into place. Once you loosen this up you can back the bolt out a few turns then make sure you retighten the locking nut. The hks ssq BOV actually makes several different sounds and some of them do kind of make a fluttering sound from the floating plate in the air valve so if the sound continues it might be normal.
Old 03-18-2004, 07:37 PM
Re: Weird BOV sound
I have the BOV connected to the brake booster by itself and I just finished loosening it up a bit. It kind of helped but it still made that fluttering sound. I'll admit that depending on how I shift it does make a different sound so maybe that's just the way the BOV is.
