I have a hard time getting the damn thing into gear. Mainly when I stopped, I have trouble putting it in 1st or Reverse. I seems that I have to let off the clutch and press it again a couple of times before it will go into gear? Does anyone else have this problem? Is it my clutch, gear box, tranny? Please help me!
Re: Re: A this is why it's called the "cash eater"
My reverse is like this. Its just synchros not lining up correctly. My crx did the same.
Saturn Stealership Technician #331 |
Mine has been known to do the same thing.
"The nympho of info, I'm fuckin' what ya heard"
Same with reverse/1st
Also my 5th gear has trouble going in if I'm shifting into it at above 3000 rpms. The way the gearbox is designed means that little oil gets to 5th and it gets bad |
when you guys go to put your car into 1st or reverse put it in 2nd first. I dont know why but it makes it easier to put it into gear. And make sure in reverse that its all the way in or itll grind like a stripper.
1991 Honda Civic DX Sedan |
This is a common problem with a lot of Hondas, the way i get it into gear is to let the car roll just a little bit and it will slip right into gear
KoRnSaQ |
yep happens to me. Sometimes i think my car is in gear....*first gear that is* and when i start giving it gas, the thing grinds like a mofo. I just have to push in harder n' it goes into gear.
1990 Honda CRX Next Project: b16a DREAMWORKS Cardomain: http://www.cardomain.com/id/importscrx |
have u adjusted ur clutch cable,if u have it might be that u adj too much.mine did that when i adj my clutch to grab lower than before.try that.
If I'm going into first gear i go to 2nd then 1st...and if I'm going reverse I go 2nd to 1st to reverse. It is a habit and always works better.
***90 Civic EX 4 Door*** ![]() Quote:
Double clutching helps to make it easier to get into reverse, same with going into a forward gear than going into reverse.
Re: Re: Re: A this is why it's called the
-Shawn '91 Civic DX sedan DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
I dont think its even just older hondas either though....Whenever i used to drive my pops 98 lude with 30k miles on it, i had problems with reverse
I'm Alex. A cookie to whoever guesses what car I'll get! ![]() I tend to hate people....expecially liberals... This is my temporary racecar-the two liter beast itself, the 87 camry:
