Old 03-17-2004, 09:28 AM
Big Bad Big Bad is offline
Question GMC 1992 Sierra
I purchased a 1992 GMC Sierra, and noticed that the climate control had a problem. When I try to go from defrost to vent to heat, it only stays on defrost. it seems that the contact in the button seems to be stuck. the button beside it which controls the fan speed,seems to work fine. Can it be that the contacts are dirty? What can I do?? Thanks.
Old 04-25-2004, 03:51 AM
e3j1c1 e3j1c1 is offline
Re: GMC 1992 Sierra
Does the display fail to change, or does the direction of the air flow fail to change? If the display doesn't respond when you change it, its probably the control. If the display changes it might be the vent flap that redirects the air is stuck. Either way, its a chore to fix.
01 sierra power steering went out after dounuts torj0752 Sierra 2 03-06-2011 10:46 PM
Problem with 4WD. 2000 sierra k1500 Z71 truckguy92 Sierra 0 09-26-2010 12:56 AM
2002 gmc sierra 3500, 8.1-flashing mil, dies/hard to start Shawn1978 Sierra 4 08-14-2009 08:11 PM
2006 gmc sierra hd 7 pole trailer plug peanpone@hotmail Sierra 0 05-02-2009 09:50 AM
