Old 03-17-2004, 07:29 AM
MechWarrior MechWarrior is offline
93 Escort Manual Transmission
I have 1.9L Ford Escort LX, how do I flush the transmission and add new fluid? I can't seem to locate the drain valve nor the filler plug. Any assistance will be greatly appreciated.
Old 03-17-2004, 02:57 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Re: 93 Escort Manual Transmission
There is no drain plug. Remove the speedo cable and sensor from the top of the tranny and use a pump to start a siphon and drain the fluid, and add it through here too. The gears on the speed sensor serve as your dipstick to show you proper fluid level.
Old 01-16-2005, 12:37 AM
spidermann59 spidermann59 is offline
Dear war, The tranny has a drain..23mm nut. As you crawl from the front look at the bottom of the tranny on the drivers side, just ahead of the axels. I figure you already changed but just in case.. chilton's or Haynes has instructions. I just changed t fluid last week ATF !! no less. good luck, David
Never Give Up!!
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
