Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 03-17-2004, 12:46 AM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
suggest turbo
I am looking for a turbo that will engage at a good 3000-3750RPM's in my 1999 accord LX... It's a 2.3 Vtec with about 74,000 miles on it.. I'm not looking to do any major boosting on it until I get a different engine this summer, and build that one up... the current engine will run on about 6-8 PSI daily IC'ed. any suggestions? I want this to improve the lower end, but still be able to keep up with the top range of the engine (6500RPM's). Would a hybrid be advisable? If there's a kit avaliable for my application where?
Thanks
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 03-17-2004, 10:27 AM
DemonicAccord's Avatar
DemonicAccord DemonicAccord is offline
Send a message via AIM to DemonicAccord
Re: suggest turbo
there are kits avail. but you can save quite a bit of dough over the kits (around 1000 depending on your component choices) if you part it together. a t3/to4e will be spooling at 3000 easy, but a ball bearing unit (read, more expensive, but worth it, for longevity too) will spool much sooner.
couple of questions tho, how important is the bling? ie, powder coated or "chrome" charge piping, a poliched or chrome compressor housing etc? doing aluminum charge piping yourself will save $$. granted steel is a little cheaper and easier to weld, aluminum is waaaaay lighter and easier to cut (assuming you don' thave a cut off wheel. couplings are cheap too. the priciest parts will be the IC, TC, mani, and DP, but a local shop should be able to fab a DP for less than $50 and most t3 flanges are about $25. I'm all over the place, I know
Old 03-17-2004, 12:48 PM
duplox's Avatar
duplox duplox is offline
Send a message via AIM to duplox
Re: Re: suggest turbo
Its not about bling... if you see a 'chrome' exhaust manifold and turbine, most likely its for heat retention.
"THERMAL BARRIER PROPERTIES REDUCE RADIANT TEMPERATURE
HIGH ABRASION RESISTANCE
INCREASED GAS VELOCITIES
REDUCED UNDER HOOD TEMPERATURES
HORSEPOWER GAINS AVERAGING 2% "
http://www.airborncoatings.com/customer/index3.html
read that. sure it looks like chrome, but it is meant for helping keep the heat in the exhaust manifold and not in the engine bay. Heat is energy, turbos use heat energy to make boost. I'm having my exhaust manifolds coated inside and out, turbine and compressor housings , all intake charge piping, valve faces, combustion chambers, and piston tops aluminum ceramic coated. Piston skirts and main bearings will be solid dry film coated. I'm considering having my intake charge piping Xylan coated, but it doesnt list how much it costs on their site. Average HP gains of 2%, probably much higher on a turbocharged engine. Reduced radiant temps mean more heat in the exhaust, reduced underhood temps mean your turbos are gettin cooler air, and increased gas velocities mean faster moving exhaust to push the turbines. In my eyes, its purely for performance. I'd be happier if it were black and not chrome, i'm not a big fan of all the bling.
Old 03-17-2004, 12:53 PM
Re: suggest turbo
i was talking about charge piping and the COMPRESSOR housing not the mani, feel free to re-read my post
Old 03-17-2004, 02:23 PM
duplox's Avatar
Re: suggest turbo
I didnt misread. I thought it was a typo. If you have the outside of your compressor housing chrome plated and not ceramic coat exhaust manifold/scroll you don't know what's good for your car and are wasting your money. Unless chrome and NOS stickers make your car faster. I don't see why you took an aggressive stance in your reply, I don't see how 'bling' pertains to the question at all. He never mentioned money, he never asked for help on how he's setting up the system, he just wanted a recommendation on a turbo. Your talk about bling doesnt help his turbo spool faster or help him chose a turbo. I was attempting to make something useful to him out of the whole 'bling' thing. Ceramic coating will help your turbo spool faster. Chrome plating your compressor will not. I was not angrily correcting you, I was informing killah_xft what a performance "chrome"/aluminum ceramic coating is for and how it helps him in his spooling problem.
Old 03-17-2004, 05:53 PM
Re: suggest turbo
whatever
Old 03-17-2004, 08:52 PM
boosted331 boosted331 is offline
The shiny silver 1300 degree paint that you get from most places like jet hot etc does dick all for performance. It fades off and peels after a year on the street, spool doesn't decrease, underhood temps don't decrease. The only coating i've used that actually does something for headers is Swain's white lightning. It's put on like .020" thick, and actually keeps a ton of heat inside the header. This is coming from experience, not just what i've heard on the internet.
Old 03-17-2004, 09:58 PM
duplox's Avatar
Re: suggest turbo
uhm. That isnt paint. It is a ceramic coating done by professionals. If it was paint then they'd just sell it, why would they make you have them do it. If they charged $160 to paint a set of headers, they'd be out of business in no time. Did I EVER say "paint", "jet hot", or anything about that. If you read the site, they have thoroughly tested their coatings against heat, abrasion, and salt.
"OXIDATION RESISTANCE:
No coating defects, slight discoloration 500 hours at 1,000 ° F
CYCLIC OXIDATION/CORROSION RESISTANCE 6 cycles : 1,000 ° F for 16 hours then salt spray (ASTM B 117) for 32 hours:
No Coating defects
ABRASION RESISTANCE (Fed. Test Method Std. No. 142):
Greater than 150 litres of sand per mil (.001 ") of coating thickness
"SALT SPRAY TEST (ASTM B117):
No red dust - 1,000 hours"
This is NOT a paint.
I've been to the place, I've talked to the employees, they know what they're doing, they're not some ripoff company who goes to home depot, buys a can of high temp aluminum paint and paints your manifolds then charges you 160 bucks. If you dont know what ceramic coating is and know what it does you dont know shit so shut up.
Old 03-18-2004, 05:39 PM
No Coating defects
Go jump on my ass for one little typo Paint, coating, spray, whatever you want to call it IT PEELS OFF. I have run this coating on 7 or 8 cars of mine, and if you drive the car on the street at all (read: heat cycling the header(s)) this stuff peels off within a year. As for the "you don't know shit so shut up" I'd like to give you a big fuck off. If everybody was as handicapped as you and took everything any company said as gospel we'd all be driving around with spiral-maxes on our car. Untill you've actually had a product on your car, don't go by shit the OWN COMPANY says about THEIR product to determine if it's good or not.
Good god, after reading that page you don't even have to be smart to figure out how badly that WILL peel, if you've never had that shit on your car before. "The aluminum-ceramic matrix provides continuous protection up to 1,200 ° F (650 ° C) and will endure intermittent exposure to 1,500 ° F (815 ° C)" 1200 degrees, gee-whiz, that will NEVER peel off. CRUISING at 70 MPH in my car I see 1250-1300 degree EGT's, and my probe is about an inch and a half off the turbo on the downpipe. I'm sure it's much hotter on the manifold. But yeah, you're right. Even though you've never used this before, the company told you it's a good product and it'll never peel, so you're right and it'll never peel.
Old 03-18-2004, 06:00 PM
duplox's Avatar
Re: suggest turbo
If this shit peels off, why would professional race engine builders put it on VALVES, PISTON FACES, AND COMBUSTION CHAMBERS?!?!?!?! the LAST thing a professional engine builder would put in an engine is big ol flakes of metal!
http://www.bacomatic.org/~dw/index.htm
Read all those engine builds. Almost all of them have ceramic coated pistons,chambers and/or valves. He's never had any complaints. AND even if it DOES peel off after a year(which I HIGHLY doubt) then its still worth it... 160 bucks a year for me to keep my v8 performing its best? worth every penny. And you're all running 4bangers, so its even cheaper for you.
Oh, and how would your manifolds be hotter than the thing thats heating them? That just doesnt make sense.
http://www.sdsefi.com/techheader.htm
A turbo header built by a professional racers, and its not being sold so no reason to discredit it! AND its ceramic coated! who coulda guessed? oh that was me. Sorry. I know people who run this exact coating from airborn coatings and they're still runnin strong. If you're are peeling, maybe its time to find a new company to coat yours. I've talked to dozens and dozens of people and no one has anything bad to say against a quality ceramic coating.
And if it was such a bad thing, why would you have run it on 7 or 8 of your cars? Must be horrible stuff.
Old 03-19-2004, 03:35 PM
Silver polished 1300 degree ceramic coating is much different from 2000 degree black ceramic coating and swains 2000+ degree poly-moly, gold-coat, and PC-9. The silver polished coatings are for "bling-bling" factor, that's IT.
I don't have a clue what you're talking about here, how about you go into more detail.
LOL, a turbo header built by professional racers. SDS builds EFI boxes, NOT turbo manifolds. That pile of crap doesn't even have a merge collector, the welding is rough and horrible, how can you even try and call it a race header. And you've "heard" from people that this stuff doesn't people. Are you sure this doesn't mean "I've made up that i've heard from people who have this to try and prove me right" [/b]
I've had 3 turbo tech kits, 1 limit engineering (maybe this is before your time, they made mustang turbo kits in the early 90's) twin low mount kit, 1 cartech kit, and a handful of cars with ceramic coated BBK shorties and almost single one of the coatings peeled off. On some of them I just left it bare and it was fine, but on others (like the TE kit and my cartech twin kit) I had the silver crap blasted off and then swain coated because the headers were too close to wires and lines and they were melting them.
Old 03-19-2004, 03:51 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
Re: suggest turbo
well boosted, that doesn't really make any sense to me.. after the first few times it peeled off, shouldn't you have started looking for a different coating??
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 03-19-2004, 09:05 PM
duplox's Avatar
Re: suggest turbo
Whatever. You go your way, I'll go mine. There is no point with argueing with you, neither of us is going to change our opinions. You have yours, I have mine. I like mine. I don't care if you like it or not... I'm sticking with it, and I'll continue to recommend it. If anyone takes mine, yours, or anyone's advice for gospel, especially over the internet, they are fools.
Old 03-19-2004, 09:07 PM
DeleriousZ's Avatar
Re: suggest turbo
woah woah woah.. so you're saying not to fully believe anything you're saying? that's a little unsettling
Old 03-19-2004, 10:00 PM
duplox's Avatar
Re: suggest turbo
Quite the contrary! "I have mine. I like mine. I don't care if you like it or not... I'm sticking with it, and I'll continue to recommend it"
I have full belief in myself and my sources(everything I research is cross checked through professionals who have nothing sell me) I'm just saying, no one should bet their engine on anything that anyone said on a forum online. If it is coming from a expert non-profit source, which I do not consider myself(you can if you want, I'll be flattered...), then yes I believe it. I live for cars and turbochargers, at least half my day is spent somewhere reading about, designing, or building cars/engines/turbo systems, and that is saying something for a college student. except weekends, 90% of my free time. My friend who helped me build my first engine who works at a Cobra replica company(or did until a few weeks ago, he quit because it was boring him) now frequently asks me for advice on building engines, as well as my older brother who was into this stuff over a year before me. But, my point is, I could be lying through my teeth right now and no one would be the wiser. Don't trust anyone you don't know - I've been on this forum for probably around a month at best, have less than 60 posts, so none of you can know me well at all. I know and trust dozens of people at the v8 forum I frequent, and I would base several important decisions entirely off of what they say. I won't mention the name of the forum for privacy reasons... last thing I need is a bunch of people I pissed off here goin there and startin shit!
The best thing you can do for yourself is to learn everything you can about engines. Not shit like... i heard this intake manifold was good, these rods suck, etc. Learn exactly how everything works, learn what all the cutting edge racing teams are doing... dont just memorize some article, KNOW what they are talking about. This is invaluable knowledge when it comes to forums and such, making it easy to sniff out bad advice... Here is an excellent source: http://www.grapeaperacing.com/GrapeA...tech/index.cfm
I'm currently studying mechanical engineering at UConn, and the knowledge I'm gettin from school also helps tremendously. I get to take Thermodynamics & Fluids and Physics next year... can't wait.
Boosted, I noticed you personally didnt have anything coated. Yours all came with your exhaust manifolds/headers. Companies are interested in making profits, they are not going to pay for a quality coating. I agree with you that if you buy a set of mass produced ceramic coated headers, the coating is trash and is just to make you go "oooh purty" and throw your money on the table. And if anyone is worried about temperature abilities of the airborn coatings place, go to jet hot and get your manifolds coated on the inside with their jet-hot 2000 stuff. Good to 2450*. Then you can get the outsides coated with the normal 1300* stuff, I assure you the outside of your headers will never get that hot with the manifolds ceramic coated on the inside. About SDS - if they're intelligent enough to design and build a proven racing EFI controller, I think its safe to say they know more than a thing or two about all aspects of engines. More than you or I, no doubt. Surely at least one of their employees have had ceramic coated headers, if they really were that worthless, why would they bother on those?
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
